Activity Forums Adobe Premiere Pro What am I missing here? non existant playback
  • What am I missing here? non existant playback
    Posted by Kris Merkel on December 7, 2011 at 4:52 pm
    I cannot get Premiere Pro to playback using the Blackmagic AVCHD 1080p sequence preset. the sequence plays for a few frames and then stops, no dropped frames warning (warning is turned on BTW) and playback res is set to 1/4
    My single biggest issue with PPro is horrible playback capabilities. I know this is an issue with my situation because I have seen demos with comparable footage run just fine.
    sequence settings are below
    MBP 2.2Ghz i7
    8gb ram
    Lacie mini thunderbolt
    BM Ultrastudio 3D thunderbolt in/SDI out
    Tom Daigon replied 14 years, 9 months ago 3 Members · 6 Replies
  • Tom Daigon
    December 7, 2011 at 4:59 pm
    I dont usr BM (prefer AJA) but the first thing to do is make sure you are using the most current drivers.
    Tom Daigon
    Avid DS / PrP / After Effects Editor
    http://www.hdshotsandcuts.com
    Mac Pro 3,1
    8 core
    10.6.8
    Nvidia Quadro 4000
    24 gigs ram
    Maxx Digital / Areca 8tb. raid
    Kona 3
  • Kris Merkel
    December 7, 2011 at 5:29 pm
    I should have put that in my post. I am using BM Desktop Video 9.0.
    This is not just a problem when using a BM sequence preset. I am experiencing inconsistant playback behavior overall and I would hate to have to re install the software because it took me 4 times of installing, uninstalling, and re installing CS5.5 before I was able to even open Premiere Pro without it crashing.
    When troubleshooting that issue Adobe support basically confirmed that the software opened in the root user, which it did, so the rest is up to me to figure out.
    The BM settings perform the worst out off all the sequence presets I have needed to use. Fortunately my workflow does not require me to use the BM settings all the time.
  • Tom Daigon
    December 7, 2011 at 5:49 pm
    If it were AJA I would tell you to call their wonderful Tech Support. Thats one of many reasons I dont buy BM. Dont like their products or support. But that doesnt help you right at the moment.
    If you are having problems with just Adobe sequences I suggest you recall Adobe support and ask specifically for Vinay who is extremely talented and helpful.
    Tom Daigon
    Mac Pro 3,1
    8 core
    10.6.8
    Nvidia Quadro 4000
    24 gigs ram
    Kona 3
  • Kris Merkel
    December 7, 2011 at 6:26 pm
    thanks for the lead. We use a mix here at the shop more so for connectivity than anything else. The BM US3d was purchased in place of the IoXT because it was available.
    I think this is more of a system issue than a BM codec problem and I will hopefully get to the bottom of it sooner than later. I am just out of the starting gate in creating 52+ user tutorials for our products as well as marketing ect.
  • Chris Tompkins
    December 8, 2011 at 11:55 am
    We’re on a Mac. Using a BMD card. Have the same issues.
    Not to mention AME not completing an output if from a BMD sequence.
    It’s sad that APP is not up to pro performance still after all these years.
    Chris Tompkins
    Video Atlanta LLC
  • Tom Daigon
    December 8, 2011 at 2:28 pm
    I think the culprit here is BMD, not Adobe. I have a Kona 3 and with recent drivers I have had ZERO problems with playback or output thru AME.
    Just sayin….
    Tom Daigon
    Mac Pro 3,1
    8 core
    10.6.8
    Nvidia Quadro 4000
    24 gigs ram
    Kona 3
