Activity Forums Adobe Premiere Pro What am I doing wrong?
  • What am I doing wrong?
    Posted by Missy Moments on May 27, 2006 at 2:17 am
    I have a 1 minute 48 second video consisting of music and video footage. For the life of me I cannot compress it correctly. Every setting I try yields a 10+ meg movie. I know it should not be that large. Please help.
    Thank you in advance!
    Bryan M Long
    Missy Moments
    Missy Moments replied 19 years, 11 months ago 3 Members · 5 Replies
  • Craig Howard
    May 27, 2006 at 4:35 am
    10 meg is not a big file in the world of video.
    Work backwards so we can give you a solution and tell you approximately what to expect as an output file size.
    What do you want to produce and for what delivery method ?.
    (Eg a 720 x 576 PAL Quicktime or a small streaming video)
    Craig Howard
    Shooter Film Company
    Auckland
    New Zealand
    (Premiere Pro 1.5 / Matrox TRX100 XTreme Pro)
  • Missy Moments
    May 27, 2006 at 4:47 am
    I am looking for a 3-4 meg file at maximum for web delivery.
    Bryan M Long
    Missy Moments
  • Aanarav Sareen
    May 27, 2006 at 5:45 am
    What compression settings are you using at the moment?
    Aanarav Sareen
    premiere@asvideoproductions.com
  • Missy Moments
    May 31, 2006 at 3:35 pm
    When I go to export to Quicktime, I use the QT 256 Streaming NTSC preset to begin with. Then I customize it by making the size 320×240, frame rate of 29.97 and the Sorensen Video 3 Codec.
    This results in a very bad quality video. How do I compress this 1 minute 40 second video and have a small yet great quality video?
  • Missy Moments
    June 1, 2006 at 3:13 pm
    Another note…
    I am using Adobe Premiere Pro 2.0 to compress. I do not have Quicktime Pro.
    The source format is DV (well TV–>VCR–>Camcorder–>Computer via Firewire)
    No I do not have the Pro version of Sorenson.
    You can see the content at http://www.MissyMoments.com click on the services tab, and it is the Family Feud video at the bottom.
    Thanks in advance,
    Missy Moments
    Bryan M Long
    Missy Moments
