Activity › Forums › Apple Final Cut Pro Legacy › What
Posted by Comando on September 26, 2007 at 9:45 am
Hey y
Comando replied 18 years, 11 months ago 2 Members · 2 Replies -
Michael Sacci
September 26, 2007 at 4:26 pmremove advance pulldown and duplicate frames
If you shot 24pA in 1080i mode this will remove the pulldown that the camera adds at recording.
If you shot 720P@24pN you need to deselect it because the camera has not added any extra frames and you get something like 18fps if you leave it on.
I would think this would be able to sense if it needs to be applied or not but it is not.
So if you shot normal interlace 60i or 24pN this should be unselected as you found out.
