Activity › Forums › Creative Community Conversations › Well, I like it…
  • Lance Bachelder
    October 28, 2016 at 12:29 am
    Me too! Been working on it for a couple of hours – yes a paid gig that was started in previous version lol – much snappier!
    One question is rec.2020 color – apparently only works on iMac or NEW Macbook Pro? Why would they care and grey it out?
    It was at a Vegas premiere that I resolved to become an avid FCPX user.
    Lance Bachelder
    Writer, Editor, Director
    Downtown Long Beach, California
    https://www.imdb.com/name/nm1680680/?ref_=fn_al_nm_1
  • James Cude
    October 28, 2016 at 12:35 am
    It looks like rec.2020 works on all installs of final cut across all systems. But you’ll only be able to see the wider colors if you have a monitor that can display those colors.
    Working with Wide Color Gamut in Final Cut Pro X
    https://images.apple.com/final-cut-pro/docs/Wide_Color_Gamut.pdf
  • Lance Bachelder
    October 28, 2016 at 12:37 am
    So my Rec. 2020 button is greyed out even though I have a Radeon R9 280x – guess it’s not new enough. Both my monitors are 4K Rec.2020 capable 🙁
    Lance Bachelder
  • Chris Harlan
    October 28, 2016 at 12:39 am
    Looks good to me! The stuff I’ve always felt was missing seems to be there. I can’t wait to play with it.
  • James Cude
    October 28, 2016 at 1:04 am
    Create a wide color library by opening up library prefs and scrolling down to the bottom to color processing.
  • Lance Bachelder
    October 28, 2016 at 5:14 am
    Yep found it thanks! It has to be set at the Library level then the Project settings will give you the option. So many cool features in this update it’s like Christmas came early!
    Lance Bachelder
  • Steve Connor
    October 28, 2016 at 8:06 am
    If, like me, you like the new version, then I’m sure Apple would be very happy if you left a review on the App Store
  • Mike Warmels
    October 28, 2016 at 10:16 am
    Frankly, it looks like they’re adding a lot of options FCP7 already had. And AVID’s had for ages (like color coding audio tracks, ordering them (here: audio lanes and moving up or down entire role), the remove attributes option).
    Is this the beginning of the end of the ‘new paradigm’. It does look like they’re reinventing stuff that’s been around for a long time.
    All I can hope is that the performance is better. Getting tired of FCPX slowness on bigger projects… err…. I mean Libraries.
  • Steve Connor
    October 28, 2016 at 11:52 am
    I’m pretty sure NO NLE has had the functionality that Rokes now offers.
  • Oliver Peters
    October 28, 2016 at 3:56 pm
    [Steve Connor] “I’m pretty sure NO NLE has had the functionality that Rokes now offers.”
    Well, except that having to step in and out of compound clips to tweak your clips levels, while trying to mix, is a roadblock. This makes the process quite modal, which is something that X is supposed to move away from. There’s no way to adjust a component dialogue clip and still have access to effects and music that’s surrounding it. It’s also something I don’t have to do in a traditional track layout.
    Oliver
    Orlando, FL
    http://www.oliverpeters.com
Page 1 of 3
