Activity Forums Apple Final Cut Pro Legacy Weirdness with Freeze Frames
  • Weirdness with Freeze Frames
    Posted by Fcp Editor on August 12, 2005 at 7:27 pm
    I’m working with FCP HD 5.0 and OS TIGER, and whenever I create a Freeze Frame or a Title card I end up getting these weird green dots that flash all over the screen…This happens when I slow a clip and apply various effects as well…
    Can’t figure it out???? Anyone know what this is?
    Jerry Hofmann replied 21 years ago 2 Members · 1 Reply
  • Jerry Hofmann
    August 13, 2005 at 1:42 am
    Sounds like a corrupted install of Quicktime or something… this isn’t normal at all. How did you perform the upgrade to Tiger? If it wasn’t an erase and install, then a total reinstall of FCP and upgrades, then I suspect your install isn’t up to snuff and is causing a wierd thing to happen when it shouldn’t…
    Post more too about your system. Is there a capture card involved? or is it just DV or?
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
