Activity Forums Adobe After Effects Weird text bug in after effects 2015.3
  • Weird text bug in after effects 2015.3
    Posted by Aindreas Gallagher on December 1, 2016 at 12:43 pm
    has anyone else had this?
    AE 2015.3 running on Mac OS Sierra 10.12.1
    When you set up a text layer and type in some copy – once you hit enter to confirm, you can no longer double click the layer to select the text again. Double clicking text layer for selection is broken?
    Also if you create a text layer, do not enter text, and then press enter so that you get a default “empty text layer” – at that point the layer is useless because there is no way of activating it to start entering text? When you double click on the text layer nothing happens – there’s just an error beep.
    That’s a bit of a bad bug.
    https://ogallchoir.prosite.com/
    producer/editor.grading/motion graphics
    Aindreas Gallagher replied 9 years, 9 months ago 4 Members · 6 Replies
  • Daniel Waldron
    December 1, 2016 at 2:40 pm
    Hmm, works for me. I’m on El Capitan though…
  • Walter Soyka
    December 1, 2016 at 6:11 pm
    First things first. Does resetting the preferences (holding Command+Option+Shift while starting Ae) help?
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Roei Tzoref
    December 1, 2016 at 9:06 pm
    [Aindreas Gallagher] “AE 2015.3 running on Mac OS Sierra 10.12.1
    there is renaming bug when using 2015.3 with Sierra. you should use CC2017 because it’s the only version that is supported for Sierra and apparently do not have bugs related to this Os.
    more about this bug and possible workarounds here: https://forums.adobe.com/message/9128208
    Roei Tzoref
    After Effects Artist & Instructor
    ♫ Ae Blues Tutorials
  • Walter Soyka
    December 1, 2016 at 9:18 pm
    What Aindreas is running into sounds different than the Sierra rename bug, the workarounds there probably don’t apply — but the point that 2015.3 and Sierra may not mix is absolutely valid.
    Walter Soyka
  • Roei Tzoref
    December 1, 2016 at 9:32 pm
    [Walter Soyka] “What Aindreas is running into sounds different than the Sierra rename bug,”
    you’re right. guess we will have to wait and see what Op can try and see what’s the issue eventually.
    Roei Tzoref
  • Aindreas Gallagher
    December 2, 2016 at 10:07 am
    Hey Walter, on the money as ever – trashing prefs fixed it.
    A
