Activity Forums AJA Video Systems Weird SVHS input problem
  • Weird SVHS input problem
    Posted by Greg Jones on November 2, 2005 at 8:21 pm
    I’m having a problem getting a signal in FCP from the AJA io. I’m seeing an image coming from all the outputs, but I’m getting a ‘Preview Disabled’ from FCP. Any suggestions. The source is a DVD player.
    Greg Jones
    D7,Inc.
    Orlando,fl.
    Bob Zelin replied 20 years, 10 months ago 3 Members · 3 Replies
  • Bob Zelin
    November 2, 2005 at 9:34 pm
    are you sure you chose S-Video input in the Audio/Video Settings/Capture Presets ?
    for sanity reasons, simply close FCP, and go into the AJA I/O control panel, and select the S-Video input, to make sure that the I/O is doing it’s thing, and passing the S-Video signal thru the IO box.
    Bob Zelin
  • Chip Monk (hd tech)
    November 3, 2005 at 1:14 pm
    Hi Greg,
    Nov 2nd must be the day the the io’s don’t work. Kevin spent 2 hours on the phone with AJA techs, still couldn’t get it to work. We almost called you. Then, like all things mac, it just started working.
    Take Care,
    Chip
  • Bob Zelin
    November 3, 2005 at 10:23 pm
    turning it off, and then on again, makes things magically work.
    Bob Zelin
