Activity Forums Apple Final Cut Pro Legacy Weird Sony XDCAM Transfer Clip Error…
  • Weird Sony XDCAM Transfer Clip Error…
    Posted by Kellen Dengler on September 14, 2009 at 8:34 pm
    I’m importing some XDCAM clips shot on an EX3 into FCP using the XDCAM Transfer application. They were shot on an SDHC card with an adapter. All of the clips are transferring over no problem except for one.
    I narrowed it down to which one is not transferring over and have tried pulling it in separately full and with In/Out points. Every single time it begins to transfer, gets about a third of the way done and then XDCAM Transfer Application gives me an error telling me the device has not been removed properly. This is very weird to me because the clip plays just fine in the XDCAM Transfer application.
    Does anyone know what could be causing this?
    Is there any other way to extract this clip?
    Bob Guerrero replied 14 years, 11 months ago 6 Members · 11 Replies
  • 11 Replies
  • Kellen Dengler
    September 14, 2009 at 9:05 pm
    OK I just tried it again and got this error message:
    “***-[NSConcreteFileHandle readDataOfLength:]: Device not configured”
    AAARRRGGGHHH!!!!
    Somebody please help!!!!
  • Mark Raudonis
    September 14, 2009 at 10:19 pm
    Could it be that specific clip spans two memory cards?
    Mark
  • Kellen Dengler
    September 15, 2009 at 12:54 am
    No it didn’t span over. The card isn’t even full and this is a clip that was shot in the middle of all the others. It’s so weird.
    Some more things I have found out that may clue someone in to what is happening:
    – Using XDCAM Clip Broswer I am able to back up every single shot on the SDHC card except this one
    – Using XDCAM Transfer I am able to import every single other clip except this one into FCP
    – Log and Transfer does not work either in FCP
    Someone else suggested using Claibrated SOftware and opening the clip in QT then exporting into something usable in FCP. Does anyone think that may work or have experience doing anything like that?
  • Brad Kopp
    September 15, 2009 at 1:36 am
    crazy idea from a newbi here.. could you import it into imovie first and drag it in that way? or drag it from the source onto the desktop and import it from there? can you copy paste it?
    Moto Guzzi rider
    dog lover w/wife, Ex & 3 kids
  • Kristin Leys
    September 15, 2009 at 2:01 am
    In the past with similar trouble clips I’ve copied the offending clip to my desktop in finder and then imported from there.
    Never struck this particular problem though so your mileage may vary.
  • Kellen Dengler
    September 15, 2009 at 2:15 am
    By copying to the desktop do you mean changing the import destination to the desktop in XDCAM Transfer?
    If so, I tried that and it doesn’t work. I can’t get this clip to export off of this card…
  • Kellen Dengler
    September 15, 2009 at 2:17 am
    Unfortunately iMovie is not compatible with XDCAM only .DV files and I cannot export the clip out of XD Clip Browser in any format. When I drag and drop it’s just an XML reference file…
  • Jeremy Garchow
    September 15, 2009 at 2:25 am
    What OS are you on?
  • Kellen Dengler
    September 15, 2009 at 2:35 am
    Leopard 10.5.8
    Both my Mac Pro and MacBook Pro are running this version of Leopard and the same problem is happening on both…
  • Kristin Leys
    September 15, 2009 at 3:08 am
    Never used this trick with an SDHC card before, so hopefully it works the way I think it does.
    In finder the card should mount as a removable drive. You should be able to access it directly on the desktop. There will be a directory called something like ‘clips’ which will contain the the actual media. Copy the appropriate file to your desktop. Then use XD Transfer to import the copy from the desktop.
    OR, you might need to copy the entire card to the desktop for this trick to work. Just copy the contents to a folder, and the point XD Transfer at that folder on your desktop.
    I’m not sure how sensitive XD Transfer is to the directory structure. Been a while since I had to do this.
    Hope it helps.
