Activity Forums Adobe Premiere Pro Weird problem with SOME transitions..
  • Weird problem with SOME transitions..
    Posted by John Duke on February 11, 2008 at 8:07 pm
    I’m trying to add any of the Iris transitions between two clips, and all that appears is a slight (VERY slight) blur between the two. No iris diamond, no iris cross, etc. And it’s weird because most of the other transitions work fine (a few of the dissolve ones have this same problem).
    What could it be?
    Jodi Engel replied 18 years, 6 months ago 4 Members · 5 Replies
  • Clyde Villegas
    February 11, 2008 at 10:15 pm
    Try hitting enter (while the sequence is highlighted) so it would render. The effect might need some rendering before you can preview it.
  • John Duke
    February 12, 2008 at 5:00 pm
    I tried that alread, and it didn’t work. What else could it be?
  • Jon Barrie
    February 13, 2008 at 12:18 am
    There must be a problem with your install as I’ve tried to use your effects with problems and they work perfectly on mine?
    – Jon 🙂
    How many editors does it take to change a light bulb?
  • John Duke
    February 13, 2008 at 1:41 am
    It’s really weird. The specific transitions work on some parts of my video, but in the later parts it doesn’t.
  • Jodi Engel
    March 12, 2008 at 1:39 pm
    I’m having the same problem with Iris transitions. They work in the program view, but when I export to an .avi file it doesn’t show up at all – like it’s just a piece missing. Other transitions seem to work fine. Anyone have suggestions?
