Activity › Forums › Adobe Premiere Pro › Weird playback issues (porbably a simple fix but i can’t find it)
  • Weird playback issues (porbably a simple fix but i can’t find it)
    Posted by Tom Opdebeeck on March 4, 2011 at 1:00 pm
    This is my first post here, I just joined the forum. I have been using it for quite a while now, it’s just that I didn’t have an urgent question untill now.
    Let me start by apologizing if this has already been posted, but I couldn’t find a thread about this particular problem.
    Whenever I play a file, whether in source or program monitor, it plays for a few seconds and then stops. It doesn’t restart, it’s not after 15 frames, it’s just at random. I’ve been looking online and on the forums and I can recall a fix for this but I can’t remember what it was.
    Looking at the problem, I’m guessing it has something to do with aborting playback on dropped frames, but I can’t seem to find the right setting to fix this.
    Weird thing about it is that it happens completely at random. It can be after 2 seconds as well as after 30 seconds, no matter what file type I use.
    My setup:
    CPU: AMD Phenom II X6 1055T (OC @ 3.5GHz)
    CPU Cooler: Scythe Mugen 2
    GPU: PowerColor Radeon HD6870
    Memory: 4x2GB Kingston Value Ram (1333)
    HDD: WD RE4 500GB (7200 rpm, 64mb)
    HDD2: WD Caviar Green 1500 GB (7200 rpm, 64mb) 2 partitions, 1 for source files, 1 for cache
    I’ve updated to the latest drivers, just reformatted and reinstalled win 7 64 bit ultimate.
    It’s not that I can’t edit the videos anymore, but it’s a big pain and it slows me down quite a bit.
    Anyway, thanks for reading and looking into it 🙂
    Tom
    Tom Opdebeeck replied 15 years, 6 months ago 3 Members · 8 Replies
  • 8 Replies
  • Jeff Pulera
    March 4, 2011 at 7:37 pm
    Hi Tom,
    Is this with CS5? What kind of footage – AVHCD, HDV, DV?
    If CS5, an Adobe-supported NVIDIA display card will make a world of difference in overall performance, it really drives CS5.
    Next, I recently read that the “Green” drives are not a good choice for video editing, something about power saving modes or whatever, they shut down or sleep or something too often.
    Also, no advantage to partitioning the video drive. This is not the same as using two separate drives, and probably does more harm than good.
    Jeff Pulera
    Safe Harbor
  • Alex Gerulaitis
    March 4, 2011 at 8:06 pm
    [Tom Opdebeeck] “HDD2: WD Caviar Green 1500 GB (7200 rpm, 64mb) 2 partitions, 1 for source files, 1 for cache”
    I am totally with Jeff on this one: WD Caviar Greens are rarely 7200rpm – mostly 5400rpm – on their good days. Partitioning them into caching and source segments for the purpose of editing high bandwidth video files is asking for trouble. It doesn’t mean necessarily this is the source of the problem – but it’s certainly outside of best practices.
    Trash Premiere preferences, import one of the Windows sample video files (C:\Users\Public\Videos\Sample Videos\Wildlife.wmv), see if this one plays w/o stopping.
    Alex (DV411)
  • Tom Opdebeeck
    March 5, 2011 at 12:45 am
    First of all, thank you for your quick replies, i have a video that needs to be finished by tomorrow and it’s already 1.35 am over here…
    yes i’m working with cs5. i didn’t know about the problems with the hdd’s, but before i was using only the caviar green (no partitionins) and everything worked fine. Do you think the partition on the 2nd hdd might be causing the problems?
    a new graphics card isn’t really an option atm, i just bought this pc in november and being a student that means i’m quite low on cash for now 🙂
    where can i find the preferences exactly? i already thought of this ;yself but couldn’t find the right files to delete (or I was a little too frustrated to keep searching…)
    (btw can someone explain why my keyboard layout has changed from azerty to qwerty in this posts editor o.O)
  • Tom Opdebeeck
    March 5, 2011 at 12:48 am
    just remembered something, when i close premiere, the process remains opened in task manager, any idea what’s going on there?
    (the azerty qwerty thing is a chrome bug, problem solved)
  • Alex Gerulaitis
    March 5, 2011 at 1:32 am
    [Tom Opdebeeck] “where can i find the preferences exactly? i already thought of this ;yself but couldn’t find the right files to delete (or I was a little too frustrated to keep searching…)”
    Try this: hold down SHIFT+CONTROL when you start the program until the splash screen appears. (source)
    Alex (DV411)
  • Alex Gerulaitis
    March 5, 2011 at 1:36 am
  • Tom Opdebeeck
    March 5, 2011 at 1:37 am
    Yeah i figured out where my preferences are saved, but it didn’t help.
    Btw the material I’m using is mainly a vob, had some trouble with importing avi’s so i’m avoiding those and sticking with mpeg. I’ve used a variety of files but the situation remains.
    Maybe a clean install might help, I don’t know, I could try in a few days.
  • Tom Opdebeeck
    March 8, 2011 at 5:48 pm
    I did a fresh install of premiere pro and imported the wildlife sample video and even with that it stops playback after every freaking second…
    I realy want to make this work, as it worked before and I want to learn After Effects better, but this is annoying the crap out of me(!).
    Is there anyone who has an idea what could be the problem here?
    The problem with the process also remains, and causes major issues when I open up premiere again, since there are 2 similar processes active then…
