Activity › Forums › Adobe Premiere Pro › Weird Opacity Issue?
  • Weird Opacity Issue?
    Posted by Ashley Ripka on July 15, 2015 at 5:49 pm
    I’m working in Premiere with a couple of layers of video. The bottom layer is slightly showing through the top layer even though the opacity is set to 100%. Does anyone know why this would be happening?
    There are no transitions of keyframes on the top layer.
    Giulio Gobbetti replied 11 years, 2 months ago 3 Members · 3 Replies
  • Ann Bens
    July 15, 2015 at 5:58 pm
    Check the blending mode.
    Adobe Certified Expert Premiere Pro CS6/CC
    Adobe Community Professional
  • Ashley Ripka
    July 15, 2015 at 7:19 pm
    It’s set to normal.
  • Giulio Gobbetti
    July 20, 2015 at 10:14 am
    Same thing here. I have seen this issue before a few months ago using “unsharp mask” and since I didn’t find a solution I just went with “shapen” instead. Now I have the same problem with “transform” – I have to rotate a clip and what is underneath appears. If nothing is underneath, then the clip gets slightly darker (which I think means that the black screen is slightly visible). Anyone knows what the problem is?
