Activity › Forums › Adobe After Effects › Weird lines in Font CS5.5
  • Angelo Lorenzo
    June 20, 2012 at 5:40 am
    My first guess, you have your color outline set to black, not set to none. Turn that off and see what you get.
    Angelo Lorenzo
    Fallen Empire – Digital Production Services
  • Benjamin Broeck
    June 20, 2012 at 9:45 pm
    See, the thing is, I have nothing on. The line is interior & not an outline to every font..
  • Dan Fredley
    June 21, 2012 at 12:46 am
    It’s because you have a 2 px stroke with faux bold enabled. Get rid of the 2 px stroke and you should be fine (change from 2 to 0 where it says stroke over fill and change it to All Fills Over All strokes)
    If you want the 2 px stroke then get rid of faux bold or put all fills over all strokes and increase the stroke size until it appears.
  • Benjamin Broeck
    June 21, 2012 at 12:51 am
    That did the trick, I must have gotten into the Character–>Fill Over Stroke section by accident when changing it to bold. Appreciate it.
  • Dan Fredley
    June 21, 2012 at 12:54 am
    Great–a better way to turn off the stroke is to just disable it permanently by selecting the stroke color (square box with square hole) then selecting the little white box that has a red line through it to choose “No Stroke Color”. Hope that helps.
