Activity Forums Apple Final Cut Pro Legacy Weird issue requestor wants fixed
  • Weird issue requestor wants fixed
    Posted by Jennifer Arani on October 2, 2009 at 6:59 pm
    Hello,
    I just finished a video for a requestor. In the Video my actress is wearing a shirt that has a white stitched logo. As of now I have a strange zebra interlacing effect happening with the logo. So let me retrace my steps.
    1st – I have the clip on track one. During the clip I have a custom gradient mask moving in from the right (this is on track 2). So it would not cover my actress up I keyframed to move her clip slightly to the left. On track 3 I have a graphic that is the background for the text. The text is just FCP standard text. The text is transitioning in with the zoom transition.
    I changed the sequence settings to “none” for interlacing as I did not like the effect it had on my text as it zoomed in.
    So after my requestor’s complaint I copied and pasted the clip into a new sequence and rest the settings to the following
    Frame Size: 720X480 NTSC DV (3:2)
    Pixel Aspect Ratio: NTSC – CCIR601 / DV(..
    Field Dominance: Lower (Even)
    Editing Timebase 29.97 (I shot at 30p)
    QT settings – DV/DVCPRO – NTSC
    When I did this the strange zebra effect only happens AFTER I move her to the side. If I set it back to “None” the strange effect starts from the beginning of the clip.
    So I have two issues – If I keep the interlacing off the logo is hot mess but If I turn the interlacing to either odd or even – I go back to the text transitions looking horrible.
    PS – I have tried export with compressor at H.264 and Mpeg4 – both exports had the same issues so I really don’t think it is the compression doing this.
    PLEASE HELP.
    Rafael Amador replied 16 years, 11 months ago 3 Members · 3 Replies
  • Mark Suszko
    October 2, 2009 at 8:04 pm
    You did already try applying the “broadcast safe” filter to this, right?
  • Jennifer Arani
    October 2, 2009 at 10:15 pm
    Yes, I tried all the presets in the filter and no luck. Someone told me it may be a luminance thing but I don’t know how to fix what he is referring to.
  • Rafael Amador
    October 3, 2009 at 1:14 am
    [Jennifer Arani] ” the right (this is on track 2). So it would not cover my actress up I keyframed to move her clip slightly to the left. On track 3 I have a graphic that is the background for the text. The text is just FCP standard text”
    Don’t use the default Text in FC. use Boris.
    [Jennifer Arani] “I changed the sequence settings to “none” for interlacing as I did not like the effect it had on my text as it zoomed in. “
    You can not just set your sequence to NONE.
    You need to drop a de-interlacer filter in the interlaced footage to make it progressive.
    [Jennifer Arani] “QT settings – DV/DVCPRO – NTSC “
    Try changing your sequence codec to Prores and export. Then convert that master to h264 or whatever other format you want.
    rafael
    http://www.nagavideo.com
