Activity › Forums › Avid Media Composer › Weird duration issue when Multi-Grouping Subclips
  • Weird duration issue when Multi-Grouping Subclips
    Posted by Jose Lopez on October 9, 2015 at 8:06 pm
    So I’ve gone through and created my stack, I am dealing with two cameras and one production audio source. Once I subclip the clips out, I notice that the durations on some of the clips (could be either camera, or the audio, with no rhyme or reason) are about one frame off from the others. I know sometimes it has to do with the tape names (both cameras have tape names and so does the Audio) but this seems strange. I’ve tried to rebuild the sequence and try subcliping again, to the same results. Any ideas of what may be causing this or how to fix this? Thanks.
    Jose Lopez replied 10 years, 11 months ago 2 Members · 2 Replies
  • Michael Phillips
    October 10, 2015 at 4:21 pm
    Could you include a sceenshot that shows the column names? Also, are all the clips of the same frame rate?
    Michael
  • Jose Lopez
    October 12, 2015 at 6:56 pm
    Actually, I discovered the issue. As I investigated I discovered that the footage seemed to be dropping frames randomly, sometimes the 7th frame, sometimes the 4th frame, it was never consistent. Turns out both cameras and the audio were being fed timecode from a lockbox, and I am now certain that the lockbox was spitting out bad timecode. The only solution I’ve come up with is to create all new masters with correct timecode now. I did a test Export and it worked when I brought it into the system (the timecode was fine). But now I have to create new masters and wondering what codec to use to export new quicktime masters. Any ideas? (This is originally C300 footage)
