Activity Forums Adobe After Effects Weird camera movement behaviour
  • Weird camera movement behaviour
    Posted by Janne Laiho on June 20, 2011 at 2:58 pm
    Hello,
    I run into a weird problem. I have a composition with a camera and 3D objects. I move the camera from one position to the next over one frame (as in mimicking cuts in a film); so I have keyframed point of interest and position. The camera should move instantly from position 1 to position 2, over one frame. However, it moves over two frames, i.e. there is a two-step movement that the camera makes.
    This two-step movement results in strange artifacting of 3D objects when the camera is in between position 1 and position 2 (i.e. where it shouldn’t be at all): 3D text is rendered as if there were multiple copies of the layers near one another.
    I have tried changing keyframe interpolation to linear, no help.
    The weirdest thing is that in previous versions of the same project this problem didn’t occur. Unfortunately I can’t recall all of the many changes I’ve made between versions, but I checked that the camera and its keyframes are identical in the working and non-working versions.
    Any help would be greatly appreciated.
    Cheers,
    Janne
    Brian Sites replied 15 years, 3 months ago 4 Members · 3 Replies
  • Bill Williams
    June 20, 2011 at 3:02 pm
    Hmmm… Couldn’t you just create a new camera at the second position?
    vurb.tv
  • Brian Charles
    June 20, 2011 at 3:09 pm
    Hold keyframes?
  • Brian Sites
    June 20, 2011 at 6:21 pm
    I haven’t experienced your exact problem, but I have run into strange behavior moving cameras in 3D environments. One trick I found (I think from this forum) was to attach (I think parent?) the camera to a null object and move the null object, not the camera (though the camera follows the null object). For reasons I don’t understand that resolved various strange camera behavior and artifacts between key frames. I’m just a novice, but perhaps this is helpful.
