Weird Audio delay in footage but only in Final Cut
Hey all I am currently Cutting a Movie Review I Captured the DVD footage I’m reviewing (That I OWN btw) using iShowu HD screen capture software. I then Converted it into proress for Final cut, It plays in quick time and all other players fine but when I take it into final cut the Audio is WAY off, I fix it and a couple time then minutes down the timeline it goes out of sync again? Im going into premiere so see if this solves the problem. But Why doe final cut do this?
I wear many hats.
http://www.gregburkepost.com
