Activity Forums VEGAS Pro Weird alignment in 4:3 SD
  • Weird alignment in 4:3 SD
    Posted by Norman Willis on August 16, 2009 at 8:31 pm
    I am making instructional video. This particular video is supposed to be a book review of our intro study. After I get the rendering right, I need to upload it to Amazon.com in 4:3, 99MB or less, .flv. (Amazon won’t take H.264). But right now there is a rendering issue.
    Because of the Media Generators bug, I am using Photoshop to make titles. I also made a translucent yellow box for a ‘highlighter’ of sorts, which I resize over the area of text that I need highlighted with Track Motion. Because each ‘highliter’ needs different placement, this ends up giving me a lot of tracks (36).
    Everything came out nice (and properly aligned) when I rendered as Sony AVC, 16:9 Widescreen HD 30p. However, some sites (and some viewers) want 4:3 SD, so I also rendered as Sony AVC, 4:3, but this caused the ‘hiliter’ and some of the secondary titling to come out misaligned. This is most obvious starting at about 6:26 on the YouTube SD upload.
    https://www.youtube.com/watch?v=-hDZWqWyoKk
    Why would everything render fine in 16:9, and then be misaligned in 4:3? And what is my best option: just render 16:9 with a much lower bitrate, and then accept the letterboxing (because it will be letterboxed anyway, since my project settings are 16:9)?
    Also, does anyone have any suggestions or comments to improve the overall quality of the video? I am new to video, so I know my work can stand a lot of improvement. I already know I hate the green shirt, because it is just too dark. It makes my face look over-exposed. But any constructive comments as far as background, lighting, camera placement, etcetera would be more than welcome.
    Thank you.
    Norman Willis
    http://www.nazareneisrael.org
    servant@nazareneisrael.org
    Dale Spetz replied 17 years, 1 month ago 3 Members · 2 Replies
  • Odd Magne nilsen
    August 17, 2009 at 5:30 am
    There are to wayes of making 4:3 out of 16:9.
    Prosject property 4:3 will give you letterbox.
    Project property 4:3, pan/crop – right click – match output will crop to 4:3.
    odd magne nilsen
    newbie
  • Dale Spetz
    August 18, 2009 at 12:43 am
    You could try doing a 4:3 render of a “nested” version of your 16:9 project. I find that this keeps things proportionately repositioned, though you will end up with a letterbox.
