Activity › Forums › Adobe Premiere Pro › Weird advice from Adobe Tech Support
  • Weird advice from Adobe Tech Support
    Posted by Harry Bromley-davenport on March 27, 2015 at 12:30 am
    I just had email exchange with one Vinay who is apparently a bigshot at Adobe PP Tech Support in India. Here it is below. I had asked him for advice on the most compatible Mac OS to use with a fresh installation of Premiere Pro CC 2014.
    Vinay: “Hi Harry, Yes, you can go directly to Yosemite 10.10.2, which seems to be working fine. Also, please do not use time machine for any kind of backup and do a fresh installation of all the applications.”
    Me: “I should not use Time Machine to back up my system and applications drive? Wow … ? Huh?”
    Vinay: “Yes, if possible avoid it for the system files as it may write the old OS files into new one and which might create issue.”
    Can any of you fine happy editors confirm this startling piece of information? And, further, is Vinay correct in stating that Yosemite 10.10.2 is a good idea?
    If not Yosemite, would someone be good enough to advise me on what is the most stable Mac OS to use with PP 2014? I am in the middle of changing setup to a Mac Pro 8 Core. 4,1 (2009) 3.33 Ghz and will be using (for the moment) an Nvidia GeForce GTX 570 CUDA graphics card.
    Any thoughts would be greatly appreciated.
    Best, Harry.
    Harry Bromley-davenport replied 11 years, 6 months ago 4 Members · 8 Replies
  • 8 Replies
  • David Roth weiss
    March 27, 2015 at 2:50 am
    Hi Harry, long time no chat… 🙂
    First, use SuperDuper or Carbon Copy Cloner to clone your boot drive to a FireWire drive. Then test it to make sure you can boot to that drive – just hold down the Option button when booting and select the new bootable FireWire drive, and it should boot like a charm. If so, you can now erase the boot drive in your computer without fear, and reinstall the OS and Adobe CC. Time Machine is NOT good for backing up system drives, as apps many times get corrupted, while cloning works perfectly.
    Meanwhile, I’d stick with Mavericks for now, as loads of folks here are having issues with Cuda drivers under Yosemite.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions
    David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
  • Harry Bromley-davenport
    March 27, 2015 at 3:38 am
    Hail, O Wise One …
    Thanks so much for responding. OK. I will do as you command. I do use SuperDuper to back up my zillions of TBs of movie files to a massive set of eSATA drives which reside in a forest of red hot toasters, so will take your advice and do the System drive the same way and eschew the Nazi Time Machine in future.
    And thanks for the advice about Yosemite … I’m moving over to (gulp) Premiere Pro and have received nothing but bad advice from the Adobe people, so it’s a relief to get reliable advice for once. Of course, this presupposes that you have not taken leave of your senses.
    Excitingly, I am upgrading from my Mac 2,1 to a 4,1 from OWC. The choice to remain in the Mac dark ages was made simply because I enjoy opening up the side of the Mac towers and fooling around with the wiring when I have nothing special to do. Plus, it’s easy on the wallet. So it’s a huge temporal leap for me of 2 full years in Mac construction – from 2007 to 2009. Phew.
    Trust all is well with you and that you are, largely, behaving sensibly.
    Pip pip.
    Best, Harry.
  • David Roth weiss
    March 27, 2015 at 3:54 am
    I too have switched over to Premiere CC in recent times, and I was luckily not as anxious to test Yosemite as many here, to their chagrin, were. Unfortunately, many of those peeps failed to clone their system drives prior to the Yosemite update, and many were thus hosed when the newest Cuda drivers for Yosemite failed them miserably, or at the very least presented them with horrific display issues.
    For the record, I am using Premiere CC 2014 8.2.0 (65) Build, CUDA Driver Version: 6.5.45, under Mavericks 10.9.5, with a GTX 680 Mac Edition, and thankfully I’ve not encountered any issues.
    Hope this helps you Harry…
    David Roth Weiss
  • David Roth weiss
    March 27, 2015 at 4:12 am
    BTW Harry, are you still here in LA LA Land, in the hills? If so, we were supposed to get together for lunch years ago, and I’m getting hungry. So, send me an email with your contact info please, to drw at drwfilms dot com.
    Later gator…
    David Roth Weiss
  • Walter Biscardi
    March 28, 2015 at 5:54 pm
    [Harry Bromley-Davenport] “Vinay: “Hi Harry, Yes, you can go directly to Yosemite 10.10.2, which seems to be working fine. Also, please do not use time machine for any kind of backup and do a fresh installation of all the applications.”
    Vinay: “Yes, if possible avoid it for the system files as it may write the old OS files into new one and which might create issue.””
    His advice is spot on. What he’s telling you is to NOT backup and then simply replace your applications back onto the system. You need to do a completely fresh install of everything.
    Back up your documents and then re-install all your apps from scratch. That’s very standard operating procedure if you’re having serious issues with your system. Start fresh.
    Usually you start by installing all of Creative Cloud and then re-installing one by one. If that doesn’t work, then you wipe the system completely clean and start over with all fresh installs.
    Walter Biscardi, Jr.
    Editor, Colorist, Director, Writer, Consultant, Author, Chef.
    HD Post and Production
    Biscardi Creative Media
    Craft and Career Advice & Training from real Working Creative Professionals
    Blog Twitter Facebook
    March 28, 2015 at 5:57 pm
    Thank you very much for the response and the advice. Greatly appreciated.
    Best wishes, Harry.
  • Ht Davis
    March 29, 2015 at 8:20 am
    I say do both. Clone a backup to restore to, just in case.
    Then do a Time machine backup.
    They don’t want you to overwrite system files? LOL!!! What a cubicle-robotic jack**s!
    When you install OSX, you can go to the recovery environment and use time machine, then elect not to restore your system, just everything else.
    Then use an uninstaller like CClean or the like to wipe all remnant of adobe from your system. Most apps will be fine if they are from apple or signed app from the app store. Others may have issues to clean up. You can fix this by wiping them from your system where needed. Like Adobe… …wipe and reinstall. Now you should be set.
    CUDA issues have arisen and are currently being addressed. While it may not be perfectly sound to upgrade to yosemite, support for mavericks is being answered with “Upgrade to yosemite”. Even on my macbook pro (2008) 2.16ghz 4gbram 256mb geforce8600m. I use it to edit in CS6 at full prores. Yeah I’ve got the b**ls to do it. It gets hot, but it still works…
    March 29, 2015 at 7:14 pm
    Many thanks for taking the time to respond. Best, Harry.
