Activity › Forums › VEGAS Pro › wedding videographer…question for DPE
  • wedding videographer…question for DPE
    Posted by Majoran Szabolcs on June 2, 2009 at 1:23 pm
    Hello,
    I’m a wedding videographer.
    I just started using Sony vegas 8 and dvd architect.
    I use a Sony HVR Z7 camcorder. This program really caught my attention (sony vegas 8).Before Son vegas 8 I used to do my work on Adobe Premier.I would like to use Sony vegas 8 from now on.
    I live in East Europe and I use Pal 4:3 format, and the movie comes out in dvd format.I spent weeks finding the best settings to get the best quality.
    My settings are: -capturing the video from mini dv casettes in a dv avi uncompressed format for my PC
    -Sony vegas project settings:
    -PAL dv
    -frame rate:25.000(PAL)
    -field order:none
    -pixel format:8 bit
    -full resolution rendering quality:best
    -motion blur type:gaussian
    -deinterlace method:none
    IN Sony Vegas every in every film sequence is checked the reduse interlace flicker option, and the field order is set to none.
    The renderin settings:dv avi
    -frame size:720×576
    -field order:none
    -video format:dv avi(PAL)
    -interleave:every frame
    In dvd architect I have the following settings: -PAL 25.000
    -progressive:yes
    -in the media file andin the menu the reduce interlce flicker is set to:on
    -the media file lengt:1h 15m 00s
    My problem is that the picture isn’t clear and when the people on the video are moving or the camera is moving we can see an interlace flicker.I would like to achive getting the best quality in TV(normal and LCD) and PC(CRT and LCD).
    What am I doing wrong?By rendering the sequence which format should I use(MPEG2).Could you specify youre answers.
    PS:Can the VASST products be dellivered to Eastern Europe?
    Martin Phillips replied 17 years, 3 months ago 4 Members · 11 Replies
  • 11 Replies
  • John Rofrano
    June 2, 2009 at 3:22 pm
    DV AVI is not uncompressed. DV25 is the compression codec that is being used. What you have after capture is interlaced PAL DV footage (regardless of what you shot on the Sony Z7).
    -PAL dv
    -field order:none
    -pixel format:8 bit
    It seems that you are causing this problem by changing the project defaults without knowing the consequences. You captured interlaced footage yet you set your project field order to none and set your deinterlaced method to none. Just use the defaults that Vegas provides.
    -frame size:720×576
    -field order:none
    Once again you have changed the default setting by changed the field order to none. You are seeing the interlacing because you told Vegas it was progressive footage when it wasn’t so it simply displays the interlace lines.
    Try using the defaults: Set your project to PAL DV and don’t change any default settings. Render to PAL MPEG2 and don’t change any settings. Vegas will do the right thing by default.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Majoran Szabolcs
    June 2, 2009 at 7:22 pm
    john you are the best!!!
    its work!!!
    but now i have another problem with DVD arhitect 4.5
    when i render in vegas the endresult its the best that i ever see but i put the rendered file in DVD arhitect the result is not good
    i can see the pixels like some interlace flicker
    my englesh is not the best sorry
    can you help me??
    thank you!!!
    this is the best forum i ever see!!!
  • Terry Esslinger
    June 2, 2009 at 8:05 pm
    majoran ,
    John will want to know how you are rendering it out of Vegas for import into DVDA. It should be as a DVDA compliant MPEG2 video stream and a separate AC3 audio stream. Also make sure that your bit rate is as high as the length of your project will allow. Use 8,000,000 CBR if you can. Anything much higher than that and some DVD players will have trouble. John will be along shortly to give you some EXPERT advice.
  • John Rofrano
    June 3, 2009 at 2:23 am
    > when i render in vegas the endresult its the best that i ever see but i put the rendered file in DVD arhitect the result is not good i can see the pixels like some interlace flicker
    Is this just on your PC monitor or are you monitoring to an external NTSC or PAL monitor? If it’s on your PC monitor then have you burned a DVD to see how it looks? PC’s are not interlaced devices so you may see things that won’t be seen in the final DVD.
    Also, if you have very small horizontal lines you may get interlace flicker. This is unavoidable because of the nature of interlaced video. A line that is the height of one field will only display half of the time and flicker on and off as a result.
    Burn a DVD and see how it looks. That’s the true test.
    ~jr
  • Majoran Szabolcs
    June 3, 2009 at 7:53 am
    yes you have right with the interlace
    but i see a dvd created by another videographer in my city how works with sony vegas 8 and dvd arhitect 4.5 and the dvd looking the same in TV and PC
    how is this possible??
    and another question is how is the original movies maked ???
    thanks!!!!!
  • John Rofrano
    June 3, 2009 at 10:45 am
    > but i see a dvd created by another videographer in my city how works with sony vegas 8 and dvd arhitect 4.5 and the dvd looking the same in TV and PC. how is this possible??
    If he is using a software DVD player on this PC to preview the DVD, it is doing the deinterlacing for him. Vegas will also deinterlace when you use your PC as a secondary monitor (although there is an option to turn this on and off)
    If you mean “Hollywood” movies, they are shot on film at 24 fps and usually converted to DVD as 24p.
    ~jr
  • Majoran Szabolcs
    June 3, 2009 at 2:39 pm
    sorry but i dont understand
    this videographer shot with a sony vx2100 camera this cannot make progressiv capturing
    I testet my dvd on a DVD player with TV and its 100% quality
    i put exact the same setting what you say before!!!!
    but a i need a solution for that the quality when i play in pc monitor to be better
    what can i do??
    convert to 24 fps and then burn to dvd??
    is this a solution for better quality??
    i cold not understand what this man make
    somebody givet to me a dvd from this man i putted in my pc its loock great and the same quality is in tv
    i have a sony hvr z7 and a sony vx2100 cameras
    do you understand what i meen??
    i see that you working for vasst
    i will buy the absolute training for sony vegas all 9 dvd and the inside the sony hvr z7 dvd
    it is posible to shipping in east europe in romania??
  • John Rofrano
    June 3, 2009 at 8:05 pm
    You don’t need to shoot progressive to render progressive. Perhaps this person did render as 24p in which case it would look fine on a PC or TV because it’s not interlaced. You can render to 24p and see if it gives you the look that you want.
    I really don’t know. Send an email to our sales office and they can tell you. All of our DVD’s are NTSC and not PAL so make sure that you can play them (or play them on your PC)
    ~jr
  • Majoran Szabolcs
    June 4, 2009 at 7:47 pm
    yes
    i have maked a test with 24p and loocks better but i dont know that the setting (project settings) and the rendering settings is right
    i using the following project setting
    pal 720X576
    field option :none (progressiv)
    full screen quality :best
    frame rate:24
    reduce interlace flicker
    the rendering settings:
    mpeg2 video stream for dvd arhitect
    rendering quality: best
    field order:none
    deinterlace methode:none
    frame rate:24
    DVDA settings
    pal 720X576
    progressiv mode yes
    reduce interlace flicker :yes
    what is your opinion to this settings???
    after the vegas rendering the stream loocks great
    after the DVDA rendering loocks better
    when i move the camera from left to right and form right to left loose quality from stream
    its loocks like the stream jumps and not focused why????
    thank you very much!!!!!!
  • John Rofrano
    June 6, 2009 at 3:45 am
    pal 720X576
    frame rate:24
    I believe we covered this before… you have to STOP changing the default settings!!! PAL video is not progressive nor is it 24fps. PAL is interlaced lower field first at 25 fps. This is what your camera shot… this is what your project should be using. Just selected the standard PAL DV (720×576, 25.000 fps) project setting and don’t change a thing.
    field order:none
    frame rate:24
    Your next problem is that PAL doesn’t support 24p. It’s not part of the DVD standard. NTSC supports 60i, 30p and 24p. PAL only supports 50i and 25p. I could not even get the MainConcept MPEG-2 encoder to make a PAL 24p file so I have no idea how you did this. The only valid progressive option for PAL is 25p.
    What you should do is change the PAL 25fps MPEG2 settings to progressive and get 25p. I did a little test and DVD Architect seemed to be OK with the PAL 25p file that I made. It did not say it would recompress it. So your best option is to use the MPEG-2 DVD Architect PAL video stream template and go into the Custom… options and change the Field order: None (progressive scan). Then save this new template as DVD Architect PAL 25p video stream and render with it.
    > when i move the camera from left to right and form right to left loose quality from stream its loocks like the stream jumps and not focused why????
    This is probably from rendering 25fps footage at 24fps without telling Vegas to just slow it down 4%. Just use 25p and you should get the deinterlaced results that you want on both your PC and DVD.
    BTW, your English is quite good. I speak no other language so I’m quite impressed. 😉
    ~jr
