Activity › Forums › Square Box CatDV › Web Services Proxies
  • Web Services Proxies
    Posted by Scott Goddard on November 5, 2013 at 9:41 am
    I have my proxies serving the the built in web client (6.8.0).
    When I try to use the new sample web services, such as the Ajax search client I can connect to the server (meta, thumbnails) but the proxies do not load. I get the quicktime question mark.
    I am guessing there is something to add in the ‘Other’ tab of the Server Config?
    Scott Goddard
    Neo Verite Limited
    https://neoverite.com
    Scott Goddard replied 12 years, 11 months ago 2 Members · 3 Replies
  • Scott Goddard
    November 5, 2013 at 10:15 am
    Seems to be a Safari issue. Works in firefox.
    Scott Goddard
    Neo Verite Limited
  • Tim Jones
    November 5, 2013 at 4:14 pm
    Are you using the new Safari under Mavericks and getting the Safari “Power Save Feature” note if you click on the QT question mark? There are a lot of “interesting” new features in Mavericks that probably should have been “left on the currying room floor” so to speak.
    Tim
    Tim Jones
    CTO – TOLIS Group, Inc.
    https://www.productionbackup.com
    BRU … because it’s the RESTORE that matters!
  • Scott Goddard
    November 5, 2013 at 4:18 pm
    It’s the older Safari I believe 6.0.4. Seems others have had issues with certain browsers too, as usual in web dev..
    On a side note, is there a player that will display timecode track?
    Scott Goddard
    Neo Verite Limited
