Activity Forums Adobe After Effects Web Project
  • Web Project
    Posted by Eric Sampson on June 14, 2006 at 6:58 pm
    Im doing my first ever web animation of a logo for the top of the webpage. The web designer said that all I need to do is make the animation just like I would for video except change the frame rate to 15fps and export as SWF.
    Anybody have any experience with this or tips before I start this new journey?
    Eric Sampson
    After Effects 7.0 Pro
    Brant Mills replied 20 years, 3 months ago 5 Members · 6 Replies
  • Steve Roberts
    June 14, 2006 at 7:05 pm
    I don’t do that very often, but you should know that a lot of features of AE won’t survive the SWF export process. Check the AE help for “SWF”.
  • Mylenium
    June 14, 2006 at 7:32 pm
    It seems unwise to export it as an SWF – either it will only increase file size unnecessarily because AE will “bake” all its stuff to pixel data even if it’s vector based or you will loose many features. in a way it’s a loose-loose situation. A much better way would be to provide your web guy with a standard video clip or a FLV file, with the first option being perhaps the better since he then could do the FLV encoding himself and tweak settings for optimum performance.
    Mylenium
    [Pour Myl
  • Daveyg
    June 14, 2006 at 8:58 pm
    you can also render out as a png file or jpeg depending on whether or not you need transparancy. go to shaveplatypus and do a search on swf and ae. i did this a bunch on
    http://www.scotlandorbust.com
    and http://www.velocityouth.com
    any time you need help let me know
  • Eric Sampson
    June 14, 2006 at 9:55 pm
    Thanks Everyone!
    side question Davey….how did you do that light glowing effect on your velocityouth website that plays over the photomontage?
  • Daveyg
    June 14, 2006 at 10:00 pm
    its just a background that comes with ae 7.0.
  • Brant Mills
    June 15, 2006 at 2:10 am
    I’ve had really good results and small file sizes by exporting a jpeg sequence of a logo into a folder and importing the files via the “import folder as frames” option into imageready – then exporting an animated gif compressed the way you need it. Works great every time. You could also import the individual frames into flash and have more control over the flv/swf encoding process as needed.
