Activity › Forums › Avid Media Composer › Ways for a matte
  • Ways for a matte
    Posted by Carlos E. martinez on March 13, 2006 at 10:12 pm
    A friend of mine suggested importing one frame onto Photoshop to use as the base to build up my matte around for my graduated ND.
    So now the stupid question: how do you export one single frame from Avid Xpress?
    Perhaps this way we can go one step at the time until I learn how to work with these things.
    Carlos E. martinez replied 20 years, 6 months ago 3 Members · 6 Replies
  • Satesh Ramjattan
    March 13, 2006 at 10:38 pm
    load your footage into the source monitor and plop on the frame you want to export and i believe you go to clip freeze frame and set a duration, after that, select the freeze frame and “export” out as a “graphic” and you can then choose the format. in your case select photoshop. that is it.
    hope that helps
  • Carlos E. martinez
    March 13, 2006 at 11:15 pm
    When I try to export the single frame, I keep getting an “Illegal instruction error”, even if the settings seem to be fine.
    What may be happening?
  • Satesh Ramjattan
    March 14, 2006 at 12:11 am
    never got that message. are you right clicking on the new freeze frame motion effect clip and then choosing export?
    March 14, 2006 at 4:12 am
    Yes. Then I pick a graphic output, Photoshop or any other, leaving on the buttons the Help asks to be. And keep getting that Error message.
    It seems to refuse to output a graphic file, because it accepts all the other ones.
    Is it something I am doing wrong?
  • Geraint Pari huws
    March 14, 2006 at 9:10 am
    carlos…
    just mark an in+out around your frame, right click, export. Check the options again.
    use marks -enable
    color levels- doen’t matter in this instance
    March 14, 2006 at 2:01 pm
    That is what I am doing, and I get the “Illegal instruction” message.
