Activity › Forums › Adobe After Effects › way to set the length of layers to match each other
  • way to set the length of layers to match each other
    Posted by Raine Parrish on November 19, 2006 at 2:47 am
    Is there a way to automatically crop the layers to match in length? I have a top layer with footage and I want the solid to match the length exactly-?
    Also- is there a way to line up the render work comp bar too? By this I mean the top slider bar that sets the render area- otherwise I’m kicking out footage that’s a frame or two longer than the original footage and it’s a problem when I drop it back into my timeline in Premiere. BTW: using PC with 6.pro
    r
    Raine Parrish replied 19 years, 10 months ago 2 Members · 2 Replies
  • Michael Duff
    November 19, 2006 at 10:16 pm
    there are shortcuts do what you are asking…. is that what you mean?
    for cropping the length of a layer just set the timeline where you want to crop, select all the layers you want to crop, then hit alt+] or alt+[
    for setting the work area use b and n – so a regular combination of shortcuts is to select a layer that is the length of your render and hit “i, b, o, n”
  • Raine Parrish
    November 20, 2006 at 5:02 pm
    Thanks! That’s just what I was looking for.
    rp
