Activity › Forums › Adobe Premiere Pro › Way to remove/delete PProject and files
  • Way to remove/delete PProject and files
    Posted by Perry Cheng on March 12, 2009 at 8:58 pm
    Upon completion of a project, how to remove all the cache, temp files, rendered files… What is best practice? Obviously, saving them in a directory will be good and then delete out the entire directory, but would premiere do this for you if you have things scattered?
    Perry
    Perry Cheng replied 17 years, 6 months ago 2 Members · 2 Replies
  • Ann Bens
    March 13, 2009 at 11:30 am
    If everything is in one folder it is simple to remove with one click.
    If things are scattered? Alas Premiere will not do this for you.
  • Perry Cheng
    March 16, 2009 at 9:52 pm
    Thanks AnnBen. That’s my conclusion as well. But I do not know what others do here. I know the cost of HDD is no issue anymore, but, as a neat freak, sometimes, I like to clean up my folders. What I end my doing was 1. Create a folder (with other subfolders in it) 2. Backup my clean folder and subdirectories to elsewhere. 3. Write a simple .bat file to delete the “used folders” along with the “preview folders” in another drive, and then copy over the clean one. That way, I don’t have to remember where things are.
    REM ******** CAUTION ********
    REM ******** PROCEED ONLY if you are SURE your old PremierePro project is NOT needed!! ******
    rd /s v:\PProFolders
    rd /s t:\PProAVPreviewFolder
    xcopy t:\PremiereFolders /e V:
    Thanks anyway.
    Perry
