Activity Forums AJA Video Systems way to find out if Kona 3 is broken
  • way to find out if Kona 3 is broken
    Posted by Jochem Van rijs on August 18, 2009 at 9:25 am
    Long time reader but now I have a problem I can not solve
    I want to output an 1080p 120min @ 25p film to HDCAM SR with 12 audio tracks (from a system I used before to do this) but when I want to edit to tape I get a scrambled up picture with interference.
    I tried a lot
    1. Control panel settings (correct)
    2. FCP user settings (correct)
    3. Driver updated (no effect)
    4. Firmware update (no effect)
    5. Clean instal OSX – FCP and Kona 3 drivers (no effect)
    6. copied sequence to a new project (no effect)
    7. made a new fcp project (used bars and tone but no effect)
    8. blacked the tape
    9. Swapped card to other mac pro
    I am running a MacPro 8 core (early 2008) with enough ram. Media is 25p 1080 uncompressed 10bit. Media is one stream and comes from 3 striped 7200rpm discs.
    (please guru’s this works. (singel stream, I do it all the time in and out with 12 tracks)
    My guess is the card is bust. Is there an way to HARD reset the actual card? Tech support I can call tomorrow as I have bought this in the Netherlands and the guy is back tomorrow from Holiday.
    Gary Adcock replied 17 years ago 2 Members · 1 Reply
  • Gary Adcock
    August 18, 2009 at 2:23 pm
    [Jochem van Rijs] “I want to output an 1080p 120min @ 25p film to HDCAM SR with 12 audio tracks (from a system I used before to do this) but when I want to edit to tape I get a scrambled up picture with interference. “
    Are you sure the deck is setup and connected correctly?
    Take FCP out of the mix.
    Use only the AJA Control Panel and the card to test your signal pathway- you should be able to see bars or ramps by using just the Kona Control Panel- At this stage if you are seeing a predominantly green image- it may be the card.
    however if the signal is working correctly (showing bars and or Ramps) from the card-then it is FCP’s setting that are creating this issue.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflow for the Digitally Inclined
    Chicago, IL
