Activity › Forums › Audio › waves z-noise — where is it in Soundtrack?
  • waves z-noise — where is it in Soundtrack?
    Posted by Aemilia Scott on September 8, 2011 at 7:54 pm
    whew, this is a bush league question, and my apologies for that.
    I am using Soundtrack and Final cut — working on removing some room tone and air conditioner noise from a track. I bought z-noise native because I heard good things about it. the audio filter shows up in final cut, however it has no special interface, and no options for creating a sound print, etc.
    I can’t find the dang thing in soundtrack. that’s my question. the install / ilok process was confusing enough that I really don’t remember where or if there was a central application. As with the other audio filters, I assume I’d find the filter and it would bring up its interface from there.
    thanks,
    aemilia
    Eric Michael cap replied 15 years ago 3 Members · 5 Replies
  • Ty Ford
    September 9, 2011 at 1:38 pm
    Hello Aemilia and welcome to the Cow Audio Forum,
    The Native version may run on its own, but not within FCP or STP. Check your applications folder to see if it’s there and fire it up.
    And, yes, the iLok process can be very annoying.
    Regards,
    Ty Ford
    Cow Audio Forum Leader
    Want better production audio?: Ty Ford’s Audio Bootcamp Field Guide
  • Aemilia Scott
    September 9, 2011 at 2:20 pm
    Thanks so much for the response, Ty.
    I do have a waves folder in /Applications, but there doesn’t seem to be a recognizable application in it.
    Here is the list of files I have. What do you think? I’m not sure I mentioned it, but I’m running mac os snow leopard on a early 2008 mac pro.
    -Utilities
    Clear_Auth_Cache.sh
    Icon
    InterLok Extensions Install
    Waves Uninstaller
    Waves 8.0 ReadMe.html
    -Waves Plug-Ins
    -Documents
    Icon
    Waves System Guide.pdf
    Z-noise.pdf
    Icon
    Plug-In Settings – new location
    WavesLib 8.0.framework
    Z-Noise.bundle
    Waveshells
    Icon
    Waves AU Reg Utility 8.0
    WaveShell-AU 8.0.component
    WaveShell-DAE 8.0.dpm
    WaveShell-VST 8.0.vst
    WaveShell-VST 8.0.vst3
  • Eric Michael cap
    September 9, 2011 at 8:14 pm
    Z-Noise is a AU Plug-In, not a Stand Alone Application like Izotope RX. In STP, go your Effects pane and scroll to the bottom of the Category tab…there should be a Waves folder w/Z-Noise in it. Click to open/activate. You can also use it within any DAW; Logic, Pro Tools, Cubase/Nuendo &/or DP. There should also be a Waves folder within your Applcations and an WaveShell AU Component under Library_Audio_Plug-Ins_Components.
  • Aemilia Scott
    September 9, 2011 at 9:00 pm
    Thanks for narrowing this down, Eric. I really appreciate it.
    So if I *don’t* see that waves folder in the categories tab of my effects pane, what might the problem be then? I don’t see anything there other than the usual categories of effects. I’m running soundtrack 3.0.1.
    in /Library/Audio/Plug-Ins/Components I have a file WaveShell-AU 8.0.component.
    The filter does show up in FCP, however without the GUI. I didn’t get any iLok or registration errors on either program launch.
    Cheers,
    aemilia
  • Eric Michael cap
    September 9, 2011 at 11:38 pm
    Try re-installing the Z-Noise plug-In…it should show up in the STP Effects palete along with and other 3rd Party AU plug-ins. Otherwise, give Waves Tech Support a call…they’re usually pretty responsive. Cheers.
