Forums › Adobe After Effects › Waves Tile Patter
Giuseppe Cacciola
May 24, 2022 at 8:56 pmHi!
For a project i need to make a wave line that has to be tileable (it has to go to c4d as a pattern).
The only tileable thing i did was a simple sine wave… the only problem with it is that when i put a motion tile, the movement loose its waviness (it’s like a wave line that goes from left to right with no movement at all). I really want to like a little more dynamic to my wave, but when i put any other effect (a turbulent displace or a wiggle) my tile.. well it’s not more a tile.
I know i need the in and out of my line to be the same… i ask you if there is something i can do to make my sine wave a little bit more dynamic.
I hope you’ll be able to understand my problem (sorry for my english mistakes).
I put two screenshots of my sine wave tiled (but with no dynamic) and the wave with a little bit of wiggle.
Thank you very much!
Log in to reply.
