Activity Forums DaVinci Resolve Waveform monitor snaps back to main Monitor
  • Waveform monitor snaps back to main Monitor
    Posted by David Smith on October 4, 2011 at 11:56 pm
    I just set up a second monitor to put my Waveform, Parade, etc. on.
    When I drag any of the 4 panels over to my 2nd monitor, they sit for 1-2 seconds then snap back my main/Resolve interface monitor.
    Does anyone know what the problem is here?
    David Smith replied 14 years, 11 months ago 2 Members · 2 Replies
  • Christopher Tay
    October 5, 2011 at 1:19 am
    Try delete the config file for the scopes window and see if it helps.
    The WFM.cfg file is located here :
    /Library/Preferences/Blackmagic Design/DaVinci Resolve
    -chrispy
  • David Smith
    October 6, 2011 at 9:32 pm
    Thanks for your reply Chris. I figured it out a few minutes later and forgot I had posted here.
    It turns out that I had set my 2nd monitor “above” my Resolve interface monitor in my monitor configuration in System Preferences in my Mac.
    For some reason Resolve did not like that. When I set the 2nd monitor to the side (even though the physical monitor is above my main monitor) it stopped snapping back.
    I will what you suggested though… I’m just curious to see if that fixes how I originally had it.
