Waveform in the source viewer not visible
Hello everyone,
I just started using Davinci Resolve and ran into a problem: I can’t view the waveform of the timeline video in the source viewer. I thought this was possible and that I could display this initially, but maybe I’m mistaken because I can’t find any settings that would change this.
Anyway, to go into more detail:
- If I use the timeline video (called by default ‘Timeline 1’), I cannot see the waveform when I select “Show Zoomed/Full Clip Audio Waveform” or when I choose to display “Audio Track” – where the waveform should be, it’s simply empty.
- The waveform appears in the timeline itself, though (it is enabled under timeline view options)
- With any other video from the media pool, there are no problems viewing the waveform.
- However, once I drag a video into the timeline and then want to view this (unedited) timeline video in the source viewer, the waveform doesn’t appear anymore.
Pictures to illustrate what I mean.
The version is 12.5.5.026 and I’m using Windows 10 64-bit.
