Activity Forums Adobe Premiere Pro Waveform display in nested sequences
  • Waveform display in nested sequences
    Posted by Joakim Dalfors on July 13, 2005 at 8:41 pm
    Hello!
    Anyone know how you get to see the waveform for a nested sequence?
    I have made some sequencies with the track matte effect and I use them in as clips in my main sequence but I do not see the waveforms in the audio track (well suddenly some of the clips showed the waveform but I do not know what made them show up and the rest do not. Since seeing the waveform simplifies the editing a lot for me I really would like to know what the problem is if anyhone happenes to have encountered this before.
    best regards
    Joakim
    Joakim Dalfors replied 21 years, 2 months ago 3 Members · 5 Replies
  • Aanarav Sareen
    July 13, 2005 at 9:35 pm
    You will have to render the sequence, in order for you to see the waveform.
    Aanarav Sareen
    Adobe Certfied Expert, Premiere Pro
    https://www.asvideoproductions.com/video
  • Joakim Dalfors
    July 14, 2005 at 5:39 am
    Thanks for the input but it does not work for me.
    In my main sequence I now have six or more clips that are nested sequencies.
    As I mentioned above, for some reason, the first two of them shows the waveforms (i do not know why and they did not do it when I put them there) and these sequencies are not rendered, i.e. they have red bar on top.
    I tried prerender some of the other sequencies as you suggested but it makes no difference, still no waveform showing up in the main sequence.
    best regards
    Joakim
  • Joakim Dalfors
    July 14, 2005 at 5:50 am
    Hi again!
    I see. Maybe you were referring to prerender the main sequence where the nested comps are placed because that seems to get the job done!
    Thanks Aaron.
    best regards
    Joakim
  • Tim Kolb
    July 14, 2005 at 12:06 pm
    [jodal] “I see. Maybe you were referring to prerender the main sequence where the nested comps are placed because that seems to get the job done”
    Yes, that’s what was meant. In order for PPro to show you a waveform, there has to be an audio file somewhere to compute it from. A nested sequence has the potential to have many audio tracks mixed together and computing what the “composite” audio waveform might look like from the mix (as opposed to simply mapping the sound from one clip)would typically just take too much computing power.
    TimK,
    Kolb Syverson Communications,
    Creative Cow Host,
    2004-2005 NAB Post Production Conference
    Premiere Pro Technical Chair,
    Author, “The Easy Guide to Premiere Pro” http://www.focalpress.com
    “Premiere Pro Fast Track DVD Series” http://www.classondemand.net
  • Joakim Dalfors
    July 14, 2005 at 4:51 pm
    It makes sense what you are saying and it works just fine now.
    Thanks again to you both (and sorry Aanarav for writing your name as Aaron in my last post)
    best regards
    Joakim
