Activity Forums AJA Video Systems Waveform Display
  • Waveform Display
    Posted by Ajith Nair on February 23, 2006 at 6:23 am
    We are using Kona LS card with Media VideoRaid RTR320 1TB on a PowerMac G5 Dual 2.7 GHz with Atto UL4D card. Whenever we try to display the wavefoam of the audio in the time line, it takes too long ang the machine also becoms slow responcing to other operations in FCP. After a long period of time the machine will show the wavvefoam and after that we can work fast on it. Is there any setting to improve the speed of this operation or any other solution to it? Please suggest.
    Thanks & Regards
    Ajith
    David Battistella replied 20 years, 7 months ago 5 Members · 5 Replies
  • Walter Biscardi
    February 23, 2006 at 1:26 pm
    Sounds like you don’t have enough RAM in your G5. You should have at least 3 – 4GB RAM in that machine. How much do you have?
    Walter Biscardi, Jr.
    Director, “The Rough Cut”
    https://www.theroughcutmovie.com
    Now Posting “Good Eats” in HD for the Food Network
  • Jerry Alto
    February 23, 2006 at 5:33 pm
    Ajith- When our timeline gets out there (over 15 minutes) we go to sequence settings and shut-off waveform ’til we need it.
    Jerry
    G5 Dual 3GB Ram
    FCP5 Studio
    External 1 TB SATA Raid 0
    Kona LH, Second system w AJA ioLA
    Sony Z-1
  • Ron Thompson
    February 24, 2006 at 9:46 pm
    The previous two suggestions are correct. I edit a 23 minute broadcast show here with 12 tracks of audio. Having the waveform on will definitely affect your workflow because FCP needs to draw and re-draw the timeline everytime the timeline is moved. RAM will help, but keeping it off until you need it is the way to go. I only use it for precision edits.
    Ron
  • Ajith Nair
    February 25, 2006 at 7:32 am
    Hi thanks for the suggestions. Its a TV editing station where we need the waveform. I have 2GB of RAM and I can check upgrading that. Will revert if I get a result. Thank you once again to all of you.
    Regards
  • David Battistella
    February 25, 2006 at 2:41 pm
    FCP only uses a MAX of 2gig of RAM so 4 gig in your machine is a big helper. The other to think about is increasing the size of the waveform cache file. This might allot more Application RAM towards doing things like drawing waveforms for you.
    David
    Peace and Love 🙂
