Activity Forums Adobe After Effects Waveform Color Filling
  • Waveform Color Filling
    Posted by Jordan Lewallen on April 23, 2015 at 12:36 am
    Hello, I am working on an audio template. I am trying to make a waveform similar to the one you can see in Soundcloud. I’ve managed to program an expression to generate the waveform. But I am having an issue with filling up the waveform with a color with respect to time. For example, do you see on soundcloud how the waveform fills up orange as the song progresses? This is the concept I am trying to work on. Here is what I have so far:
    This is a continuation of a project that a user on here by the name of Kevin Camp (if you’re still active on this forum) helped someone out about a year ago. Here is a link to the original post with the process I used: https://forums.creativecow.net/thread/227/27263
    I want the blue bar to move to the right over time, but I only want the white parts of the waveform to turn blue as it progresses (the rest of the blue solid hidden). How would I go about doing this? My knowledge in After Effects is limited so any help is GREATLY appreciated! Thank you
    Michael Szalapski replied 11 years, 4 months ago 3 Members · 3 Replies
  • Tudor “ted” jelescu
    April 23, 2015 at 6:37 am
    Use the Waveform you generate as a Track Matte for the blue solid, combined with an animated mask that reveals the color as the music progresses.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Jordan Lewallen
    April 23, 2015 at 1:34 pm
    That’s what I was thinking, but I was using this expression code featured here: https://forums.creativecow.net/thread/227/27263
    I have to duplicate each solid (to generate the waveform seen in the picture) about 100 times.
    Is there a way to disable the expression code but keep its parameters so that I could duplicate it and add it as a layer above it? Does that make sense?
    Basically, I don’t have just one solid waveform, I have a whole bunch of duplicates to generate the whole waveform therefore I cannot do a track matte :/
  • Michael Szalapski
    April 23, 2015 at 2:48 pm
    You can do a track matte if you precomp all of the layers together and use the resulting composition as the track matte.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
