Activity Forums Adobe After Effects wave like effect
  • wave like effect
    Posted by Salar Sardary on February 13, 2019 at 8:09 pm
    Hello all! I am stuck to come up with the trick to create the similar effect you see in the video
    I used trim path and change the position and this is the result I reached
    But I still lack the part that acts like a whip (the part in the red circle below)
    many thanks in advance for your help!
    Harry Hoag replied 7 years, 6 months ago 5 Members · 4 Replies
  • Richard Garabedain
    February 14, 2019 at 4:36 pm
    Try using the polar coordinates or maybe one of the VR effects on an adjustment layer then playing with the line work below. maybe that will work
  • Max Haller
    February 15, 2019 at 7:35 pm
    I would think you’d have to animate the path itself to move in that whipping shape
  • Oleg Pirogov
    February 16, 2019 at 2:21 am
    I see here a whip following the dots.
    Dots are animated and arranged in a strict order which can be done one way or another:
    Running a coarse line through them can be done with createPath():
    Smoothing it is a different problem which I don’t really know how to address.
    I can do some smoothing with a version of a script from here: https://forums.creativecow.net/thread/2/1134161 like this:
    But as you see, it differs from the gif. All I’m sure is that that line on the gif is smoothed not with Auto Bezier.
  • Harry Hoag
    February 16, 2019 at 10:27 am
    You could try what Oleg did but attach a precomped line with puppet tools to the nulls, that would auto smooth to a certain extent. But I imagine it’ll look like what he has with the auto smooth script thing.
    Or use ‘extended points to nulls’ to have full bezier control and just spend a bit of time manually animating the beziers so they look smooth, that shouldn’t be too painful.
