Activity Forums Adobe After Effects Expressions Wave Delay in Y Position Only
  • Wave Delay in Y Position Only
    Posted by Robert Elliott on May 4, 2010 at 10:30 pm
    Hi all,
    I’ve got a series of objects I’d like to animate like a wave across the screen. I want them to move up and down in their y position only. I’m thinking this can be done with a delay, but how can I constrain it to be only along the Y position for each layer?
    Rob
    Dan Ebberts
    replied 16 years, 4 months ago
    2 Members · 3 Replies
  • Dan Ebberts
    May 4, 2010 at 11:26 pm
    I’m not sure what you’re doing, but this might help. This expression should cause a layer to oscillate up and down only, based on its x position in the comp. So it should generate a wave if you have a bunch of layers (with the same pre-expression y value) arranged in a horizontal line.
    freq = 1; // one oscillation per second
    amplitude = 50; // up and down 50 pixels
    P = toWorld(anchorPoint);
    phase = (P[0]/thisComp.width)*Math.PI*2;
    y = amplitude*Math.sin(time*freq*Math.PI*2 + phase);
    value + [0,y]
    Dan
  • Robert Elliott
    May 5, 2010 at 12:08 am
    Thanks Dan. That’s a nice effect and might help with another task I need to deal with next. I was looking for more of a follow the leader kind of look where I could keyframe one object and have the others follow. I was able to get closer by searching deeper through the posts and modifying one to get this:
    delay = 10; //number of frames to delay
    d = delay*thisComp.frameDuration*(index – 1);
    [position[0], thisComp.layer(“1”).transform.position.valueAtTime(time – d) [1]]
    I’ve got 18 objects. Is there a way to lesson the Y value of each layer so it doesn’t rise above the Y position of its previous layer? Does that make sense?
    Rob
  • Dan Ebberts
    May 5, 2010 at 2:11 am
    Probably, but it’s hard to pin down without more information about how you want it to work. Maybe some numeric examples would help.
    Dan
