Activity Forums Apple Final Cut Pro Legacy WAV Surround Sound
  • WAV Surround Sound
    Posted by Bob Guerrero on September 20, 2010 at 5:46 pm
    I am hoping someone has a suggestion for me.
    I need to export a video using WAV audio in 6 channel surround. The digital cinema package software (DCP) that I will be processing the footage in requires the audio in WAV.
    I follow the process as outlined below, but when I get to the Sound Setting option in Quicktime Conversions, I am not allowed to select a surround config from the list.
    Any ideas of what I might try?
    – Sequence Settings
    – Audio Outputs
    – Load Audio Output Presets
    – 5.1 Monitoring
    – General
    – Audio Settings
    – Config
    – Discrete Channels
    – Edit Panel
    – Audio Outputs
    – Assign each Track 1 thru 6
    – File
    – Export
    – Using Quicktime Conversions
    – Format: Quicktime Movie
    – Options: Sound Settings
    – Channels
    – Only Mono & Stereo (LR) are selectable.
    (All other surround selections are grayed out.)
    Bob Guerrero replied 15 years, 11 months ago 2 Members · 2 Replies
  • Mark Petereit
    September 20, 2010 at 7:42 pm
    Why not just export your audio tracks separately (i.e. individual .wav files) and import them into DCP?
  • Bob Guerrero
    September 20, 2010 at 7:54 pm
    Sadly, the DCP software will process only complete files at a time. If no audio channels have data, the tracks are filled with white noise.
