Activity Forums Apple Final Cut Pro Legacy WAV out of sync with 30fps footage
  • WAV out of sync with 30fps footage
    Posted by Gavin Williams on January 28, 2014 at 2:22 pm
    Hi
    I filmed footage at 30fps on my 5D Mark 3 and recorded the audio on radio mics at 48khz, Now I am trying to sync and it starts off ok and then starts to lose sync?
    Any ideas would be much appreciated!
    Gavin
    Gary Milligan replied 12 years, 7 months ago 2 Members · 5 Replies
  • Gavin Williams
    January 28, 2014 at 3:46 pm
    Hi Dave
    It was shot on a 7D and said 30fps but am unsure if that really is 29.97?
    I have set up FInal Cut to match the settings of the clip though (as in I dragged one into the timeline and let Final Cut ask me if I wanted to change the settings of sequence to match clip to which I said yes)
    Gav
  • Gavin Williams
    January 28, 2014 at 4:00 pm
    Both are 29.97
  • Gavin Williams
    January 28, 2014 at 4:01 pm
    Oh wait – by saying two cameras did you mean the WAV audio file and the camera?
  • Gavin Williams
    January 28, 2014 at 4:15 pm
    The WAV was from a Lapel mic I used – when would a frame rate have been set to the audio then – there is no option to set a frame rate with the mic?
  • Gary Milligan
    January 28, 2014 at 5:46 pm
    Unless you’re using FCPX, make sure the video files from the camera are transcoded to ProRes before trying to edit with them. My guess is you haven’t done this and the computer can’t keep up with playing the video in real-time resulting in the loss of sync. I’m also guessing that Dave misinterpreted your post and assumed you shot using a double system set-up – sorry Dave. I’m assuming you recorded audio with a lapel mic plugged into the camera.
    I reserve the right to be wrong.
    HTH
    Gary
