Activity › Forums › VEGAS Pro › WAV or AIF files?
  • WAV or AIF files?
    Posted by Roger Bansemer on February 12, 2011 at 5:37 pm
    I recently purchased some buy out music. It has both WAV and AIF file format.
    I’ve never used the AIF files. What’s the difference and is there any advantage to using one over the other?
    Matt Crowley replied 15 years, 7 months ago 2 Members · 1 Reply
  • Matt Crowley
    February 12, 2011 at 5:46 pm
    AIFF is basically WAV for Macs – uncompressed PCM with same/similar format support. They should both be fine in Vegas but you may as well stick with WAV if you’re mainly using PCs because it’s probably more widely supported.
