Activity Forums Apple Final Cut Pro Legacy wav file playback slipping out of sync
  • wav file playback slipping out of sync
    Posted by Ceri Allen on December 21, 2011 at 9:13 pm
    Hi
    I am a bit stumped with an audio issue, and audio is not my field so I would appreciate some help.
    I have edited a 1 hour show in FCP, exported a quicktime movie and OMFs for the dub house.
    From the dub house I have received a stereo .wav file then I then lay back to my pictures.
    This has been the workflow for the previous 3 episodes and worked fine.
    For the 4th episode the stereo wav that I am matching to my pictures slips out of sync gradually. I have spoken with the dub house and they are 100% certain that it syncs up all the way through when they check it.
    When I look at the waveform in FCP the waveform actually matches that of the original quicktime audio so theoretically it looks in sync. When I play it back what I can hear from the wav is playing out of sync with both the pictures, the original audio from the quicktime movie and the waveform for the stereo wav that I am seeing visually!!!!!
    I have tested it on FCP on my edit suite at work and my own laptop at home and it happens with both. I have also tried converting the wav to an quicktime file (audio only) and this makes no difference.
    To give you the info:
    pictures are: apple pro res 422, 1920×1080, 25fps
    OMFs were made at 16 bit 48KHz.
    Wav file from dub house is 16 bit 48KHz
    Timeline settings in FCP are: Apple pro res 422, 1920×1080, 25fps, 48Kz, 16-bit
    Thanks!!!!!
    Ceri Allen replied 14 years, 8 months ago 2 Members · 3 Replies
  • Ceri Allen
    December 21, 2011 at 9:35 pm
    Also just to add I have discovered that if I change the speed of this wav file to 99.9% on my FCP timeline then it syncs up fine. Don’t know if this helps shed any light on why/where the problem is.
  • Matt Lyon
    December 22, 2011 at 3:21 am
    It sounds like you might have imported the wav file with the wrong settings in place. My tutorial describes the proper workflow to avoid these sync issues:
    https://library.creativecow.net/lyon_matt/fixing-fcp-assets/1
    see the second half (after the xml stuff).
    hth,
    Matt Lyon
    Editor
    Toronto
  • Ceri Allen
    December 22, 2011 at 3:47 pm
    Thanks.
    That worked. I just set my presets and brought the wav back in and it synced up fine. Did an XML to check it was NTSC FALSE and timebase 25. All good, thanks!
