Activity Forums Maxon Cinema 4D Watewater in a glass ball C4Dr
  • Watewater in a glass ball C4Dr
    Posted by Pablo Aguilar on March 14, 2015 at 12:45 am
    hi fellas!
    I’m doing a crystal ball containing water inside, I’m using simulation tags, to create water I’m using metaball but the problem is I do not know how to make crystal ball contains water from the beginning.
    sorry for my English is not my native language.
    Thanks!!
    Marpi
    Brian Jones replied 11 years, 5 months ago 2 Members · 1 Reply
  • Brian Jones
    March 14, 2015 at 4:33 am
    using particles to make the water? But you want to fill the container before frame 0? If yes, you can start the particles early – you can move the timeline into negative frames and start the particles early so you have enough by the ‘start’ – frame zero I’m guessing.
