Activity › Forums › Adobe Photoshop › Watermarking/branding images with filename script saving issue
  • Watermarking/branding images with filename script saving issue
    Posted by Patrick Wagner on May 19, 2011 at 4:13 pm
    I use a script that was from an old post and I’m having some troubles.
    I want to print and/or save my files with the watermark of the filename (which works correctly in the script below)
    My script loads all images in a folder I specify and then it adds the layer with the filename and that’s it.
    I really need it to save as a jpg or png once the layer with filename has been added.
    Can someone please help me with this last saving function issue??
    Thank you in advance,
    the script is below
    ——start——–
    Description:
    This script is a template script that will
    open and process a folder of images
    // enable double clicking from the
    // Macintosh Finder or the Windows Explorer
    #target photoshop
    // Make Photoshop the frontmost application
    // in case we double clicked the file
    app.bringToFront();
    // SET-UP //
    // A list of file extensions to skip, keep them lower case
    gFilesToSkip = Array( “db”, “xmp”, “thm”, “txt”, “doc”, “md0”, “tb0”, “adobebridgedb”, “adobebridgedbt”, “bc”, “bct” );
    // Pops open a dialog for the user to
    // choose the folder of documents to process
    var inputFolder = Folder.selectDialog(“Select a folder of documents to process”);
    // set the output folder
    var outputFolder = Folder.selectDialog(“Select a folder for the output files”);
    // MAIN //
    // Open Folder of Images
    OpenFolder();
    // show the path to an output folder
    alert(outputFolder);
    // FUNCTIONS //
    // Given the a Folder of files, open them
    function OpenFolder() {
    var filesOpened = 0;
    var fileList = inputFolder.getFiles();
    for ( var i = 0; i < fileList.length; i++ ) {
    // Make sure all the files in the folder are compatible with PS
    if ( fileList[i] instanceof File && ! fileList[i].hidden && ! IsFileOneOfThese( fileList[i], gFilesToSkip )) {
    open( fileList[i] );
    filesOpened++;
    // Put all your processing functions… //
    // Alert and show the document name
    alert(app.activeDocument.name);
    var originalUnits = app.preferences.rulerUnits
    app.preferences.rulerUnits = Units.PIXELS
    app.foregroundColor.rgb.red = 255
    app.foregroundColor.rgb.green = 255
    app.foregroundColor.rgb.blue = 255
    // add the pixel position for the left side of your text block below
    var textLeftPosition= 260
    // add the pixel position for the bottom of your text block below
    var textBottomPosition= 260
    var typeLayer = app.activeDocument.artLayers.add();
    typeLayer.name = app.activeDocument.name;
    typeLayer.kind = LayerKind.TEXT;
    typeLayer.textItem.size = 48;
    typeLayer.textItem.position = [textLeftPosition, textBottomPosition];
    var layerName = typeLayer.name
    typeLayer.textItem.contents = layerName;
    // Cloes the file without saving
    //Save as a JPEG to the outputFolder
    // Close without saving
    // …in the area between these two comments. //
    // given a file name and a list of extensions
    // determine if this file is in the list of extensions
    function IsFileOneOfThese( inFileName, inArrayOfFileExtensions ) {
    var lastDot = inFileName.toString().lastIndexOf( “.” );
    if ( lastDot == -1 ) {
    return false;
    var strLength = inFileName.toString().length;
    var extension = inFileName.toString().substr( lastDot + 1, strLength – lastDot );
    extension = extension.toLowerCase();
    for (var i = 0; i < inArrayOfFileExtensions.length; i++ ) {
    if ( extension == inArrayOfFileExtensions[i] ) {
    return true;
    return false;
    ——-END———
    Thank you for your help.
    I need help ASAP since I need to complete this project shortly
    Patrick
    Richard Harrington replied 15 years, 4 months ago 2 Members · 1 Reply
  • Richard Harrington
    May 26, 2011 at 4:43 pm
    Look at the Image Processor script built in to Phostshop
    Richard M. Harrington, PMP
    Author: From Still to Motion, Video Made on a Mac, Photoshop for Video, Understanding Adobe Photoshop, Final Cut Studio On the Spot and Motion Graphics with Adobe Creative Suite 5 Studio Techniques
