Activity › Forums › Maxon Cinema 4D › Watermarking Active Camera
  • Watermarking Active Camera
    Posted by Aaron Martinez on May 6, 2015 at 2:19 pm
    Hello,
    I am using C4D as a pre vis tool to create storyboards for a film.
    Using the STAGE object, I am cutting between several cameras.
    I would love to display specific camera information.
    – Camera Name
    – Focal Length
    – Focal Distance
    – F-Stop
    Using the WATERMARK render effect I can easily display the Camera Name.
    I am curious to know if there is a way, presumably using XPRESSO, to access and display the specific Camera info without having to keyframe it manually when the camera cuts…
    That is to say I am looking for tips on developing an expression that would automatically display the desired info like a watermark. I am confident I can figure out the channeling an output into an onscreen watermark like text.
    But i do not know how to access the desired active camera information…
    any tips would be appreciated… I want to say Lists may be helpful, but i never really understood them…
    Aaron Martinez replied 11 years, 4 months ago 1 Member · 1 Reply
  • Aaron Martinez
    May 6, 2015 at 5:35 pm
    I found a solution…
    in Render Settings / Watermark / Text field there is a triangle button.
    Click that and a menu of variables pops up.
    You can set among other things C4D version info, System, Project, Render and CAMERA SETTINGS.
    Works great!
