Activity Forums Maxon Cinema 4D Water/Lawn Sprinkler Animation
  • Water/Lawn Sprinkler Animation
    Posted by Courtis Merry on March 8, 2016 at 5:23 pm
    Wondering in anyone has done something similar to this and can offer some workflow advice. (please refer to still image)
    I need to animate the flow of water coming from both a round and straight sprinkler (it doesn’t really need to look like real water). I need to be able to change the flow height and width as it rotates/is affected by wind. I’m wondering if this is something that could be done easiest with a stroke (3D stroke?) or if I should go for something bigger (particular). How would you go about it? Maybe After Effects isn’t even the easiest tool, would Cinema 4D be easier? If Cinema 4D would be better, please keep in mind I only have the broadcast version.
    Any ideas would be helpful! Thanks!
    Brian Jones replied 10 years, 6 months ago 2 Members · 1 Reply
  • Brian Jones
    March 9, 2016 at 12:20 am
    so no TP and assuming no x-particles and dynamics would be from a cloner/matrix/fracture object only so emission is more of a problem but basic particles have gravity and wind, just the value are not particularly world-scale especially the wind in relation to the emitter Speed but all values are keyframe-able, so totally doable in C4D
