Activity Forums Maxon Cinema 4D Water shows through bottom of row boat.
  • Water shows through bottom of row boat.
    Posted by Matt Lamothe on October 30, 2012 at 9:06 pm
    I’ve got a model of a boat floating on a plane(water) I’ve deformed the plane using a wind deformer. The problem I’m having is that where the row boat contacts the water. How do i displace the water or at least keep it from showing up inside the boat? I tried using a boole and have messed around with a surface deformed but can’t seem to figure this out.
    Thanks for any insights you might have.
    Matt
    Matt Lamothe replied 13 years, 10 months ago 2 Members · 2 Replies
  • Brian Jones
    October 31, 2012 at 12:03 am
    Boole should work if you have a proxy of the boat to do the cutting and connect the real boat’s movement to the proxy’s via xpresso.
    4884_booleboattrial.c4d.zip
  • Matt Lamothe
    November 2, 2012 at 6:08 am
    Amazing. thank you for this solution. Really quite a bit trickier than I thought
    Matt
