Activity Forums Adobe After Effects Expressions Water ripple scaling of shapes
  • Water ripple scaling of shapes
    Posted by Rowan De geus on February 16, 2018 at 7:23 pm
    I have a grid of shape layers (all small circles spaced with gaps) that together form the map of my country.
    What needs to happen (visually speaking): an object falls into the center of the map, which then creates an invisible water ripple towards the outside of the screen.
    In essence: I guess all these shape layer circles need to do is scale up and down from their center anchor point when “touching” the ripple. Normally I would use a displacement map, but that would give me a distorted result compared to scaling the circles up and down.
    My thoughts:
    I have an expression that scales a layer relative to the distance of another layer, and a script that rotates a layer using sin/cosin.
    So maybe I just: make a null start rotating in circles with really high speed that keeps increasing its radius (essentially simulating a water ripple). Then apply a scaling script to all shapes relative to the distance of the rotating null…?
    I hope you can help me set this up ☺
    Thanks for reading, greets!
    EDIT:
    Solved! Using RG Trapcode Form to create a grid of circles that scale using a gradient map.
    Rowan De geus replied 8 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
