Activity › Forums › Apple Final Cut Pro Legacy › watch your dissolves in fcp 5
David Roth weiss
October 12, 2005 at 3:51 amCharlie,
I apologize for the pilot error comment, and additionally, I tried it out and cross dissolves do work before and after a gap. On the other hand, I have FCP 5, Tiger, Blackmagic card, and drivers, yet the cross dissolve is working on my system. Hope you figure out you problem.
DRW
Aaron Neitz
October 12, 2005 at 3:56 amit’s not a consistent problem. like i said, it worked, then after an ETT, it stopped. it may also be particular to working in 8 and 10 bit uncomrpessed timlimes. there’s so many variables, trying it once doesn’t prove system stability.
David Roth weiss
October 12, 2005 at 4:02 am[CharlieX] “it may also be particular to working in 8 and 10 bit uncomrpessed timlimes”
Charlie,
I just tested on an 8-bit uncompressed timeline, so you can probably rule that one out…
DRW
Aaron Neitz
October 12, 2005 at 4:06 am.. . . . . . yes, i’m working in 8 bit. like i said, it worked, then it stopped working after ETT. after it stopped working the only way to get a dissolve to work was to force the “Full” RT effect to render. this is not a consistant problem. that’s what’s bugging the f*** out of me. there’s nothing i can specifically point to that I’ve done or the machine has done that’s causing this. i’ve had problem earlier this week with dissolves and Text3D.
i can do a dissolve right now in my timeline and it works. but i could turn around tomorrow and find it glitches.
Annaël Beauchemin
October 12, 2005 at 6:39 amWas the project upgraded from FCP 4.5 ? I did encounter similar issues when updating medium to big projects from a previous version.
Walter Biscardi
October 12, 2005 at 11:10 am[CharlieX] “I had a piece of media, with a dissolve to black (empty on the timeline). A 2 second gap and then a fade up. Cross dissolve isn’t working, it’s just popping on and off. I’ve removed the dissolve, I’ve trimmed the frames a little, I put new dissolves on it, it just won’t work.”
Cross dissolves are working just fine here fading to an empty gap in the timeline. DVCPro HD, 720 8bit, SD 8bit, SD 10bit. Been editing straight through for about 3 weeks now and I would have noticed this one right away if it popped up.
Running 5.0.2 with Kona 2 and Tiger 10.4.2.
Walter Biscardi, Jr.
Creative Genius, Biscardi Creative Media
https://www.biscardicreative.comNow in Production, “The Rough Cut,” https://www.theroughcutmovie.com
Now editing “Good Eats” in HD for the Food Network
G5 Dual 2.0, AJA Kona 2, Medea FCR2X
Aaron Neitz
October 12, 2005 at 5:02 pmwas an upgrade. been solid so far. going to archive and install a new tiger today.
