Activity › Forums › Apple Final Cut Pro Legacy › watch your dissolves in fcp 5
Posted by Aaron Neitz on October 11, 2005 at 11:49 pmI had a piece of media, with a dissolve to black (empty on the timeline). A 2 second gap and then a fade up. Cross dissolve isn’t working, it’s just popping on and off. I’ve removed the dissolve, I’ve trimmed the frames a little, I put new dissolves on it, it just won’t work.
Yes, it’s a “Full” RT effect, and if you force render the effect it works, or if you put SLUG in instead of dead space it works…..
this release is just so buggy. watch it like a hawk!
Aaron Neitz replied 20 years, 11 months ago 8 Members · 17 Replies -
David Roth weiss
October 12, 2005 at 12:00 am[CharlieX] “this release is just so buggy. watch it like a hawk!”
Sorry Charlie, but I’d be willing to bet a fortune on pilot error rather than a bug.
Did you by any chance ever try to use a “fade in fade out dissolve”???
Aaron Neitz
October 12, 2005 at 12:14 amIt’s there. I physically see it. I can remove the dissolve and put a new one in…. no go unless hard commit to disk. I’ve been using FCP since version 2, and in a professional edit house since ver 3 – It’s not pilot error this time. I *wish* it was. Then i wouldn’t be so paranoid. Cross dissolve has worked fine in this situation for over 100 projects, but since coming to 5, there are gremlins everywhere.
Tom Wolsky
October 12, 2005 at 12:31 amI have never seen that one in any version of FCP, including v5. I’m guessing you need to reinstall. I’m assuming you’ve trashed your preferences already.
David Roth weiss
October 12, 2005 at 12:34 amCharlie,
I’m relatively new to FCP, and I only know ver. 5, but I’m guessing that perhaps they’ve made a change, cuz I’ve been using fade in – fade out dissolve for this type of transition since I started, because cross dissolve wouldn’t work. I may be completely worng, but something tells me that all you need to do is try a slightly different transition…
DRW
Pete
October 12, 2005 at 12:37 amCharlie , I had same problem, last week, I just put the 2 clips on different layers and used the keyframes tp manually dissolve to and from.
Aaron Neitz
October 12, 2005 at 12:58 amThanks for confirming!!!
It worked when the director was in, but when I went to ETT, it stopped working. I need a complete re-install from the ground up and hope that cleans out some of the gremlins. But this is a really trim system to being with….
Gary Adcock
October 12, 2005 at 2:28 amDo you by chance have the caps lock key on?
Gary Adcock
Studio37
HD and Film Consultation
Chicago, IL USA -
Aaron Neitz
October 12, 2005 at 2:46 amgood guess, but no. it’s off.
I honestly don’t know if FCP 5 is so much buggy as a whole combination of QT 7, Tiger, Blackmagic Drivers, and FCP 5. Guys on AJA Io systems in house can’t replicate these problems. But then again, sometimes I can’t replicate the problem on my own system.
Shane Ross
October 12, 2005 at 3:38 amWell, I have to join the other camp to say that I just tried it and it is working fine for me.
FCP 5.0 on a dual 2.0 running Tiger
