Activity › Forums › Adobe Premiere Pro › Was wondering if it usually take this long
John Høeg replied 13 years, 3 months ago 6 Members · 21 Replies
John Høeg
July 3, 2013 at 8:41 pmFound out the audio problem I had was due to my headset so it was not really a audio problem. (my headset is a 7.1 but it was showing as 2.1 in option settings so it could not detect the voices from the video. only the guitar rift. when I set it up to 7.1 everything worked perfectly. also tried on my 2.0 speakers and those were also good(well as good as a 2 dollers usb speakerset))
The video can’t be cut into smaller sizes since the reason behind the video was it should be 10 hours long.
But any case thank you for the help all. ill continue with H.264 even though size is a bit higher than normal. at least the audio quality is top notch.
