Activity › Forums › Adobe Premiere Pro › Warp Stabilizer Auto-crop
  • Warp Stabilizer Auto-crop
    Posted by Will Stewart on November 8, 2012 at 8:36 pm
    I just installed CS6 production and wanted to test out the warp stabilizer on some side track footage that I have. Most everything I had seen online said you could just plug it into the clip and it would work.
    When I apply the effect, it crops my image down to an EXTREME letterbox, and brings the sides in from the edge. My sequence is 1080p, shot on a 5dmkii. I don’t know what to do to fix it, I’ve played with all the parameters, no luck. I opened After Effects to try it in there as well, same result. Can anyone explain why it is doing this to my footage?
    Will Stewart replied 13 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
