Warnings and problems with a Sony 32GB SXS-1 card and other questions
I’m shooting weddings in Europe with a Sony EX3 and two 32GB SXS-1 cards in slots A & B. Full HD at 35mbps.
I was shooting speeches at a wedding on November 6th 2010, and halfway through the Best Man’s speech, the camera went off and came back on. There was a message on screen:
“Media Error: Media needs to be restored” (or a variation of that message)
It asked if I wanted to ‘execute’ the command. I did so. The camera changed the slot to ‘B’ and began recording again, missing only a few seconds (mainly applause).
It was one of my first shoots with the EX3 and I got such a fright that I nearly collapsed.
I checked the footage later on and nothing was missing on either card.
I asked another XDCAM friend about it and he said that it happened to him before but not while shooting.
I thought nothing much of it, because the footage wasn’t ruined in any way. I thought it might be just “one of those things” that happens.
I shot many weddings between then and last Saturday, the 15th of January. No problems.
Then, during a speech (I film speeches on a tripod) on Saturday, the same thing happened. No footage ruined, just a few seconds missing.
I consulted the manual and did a bit of research online, and it seems that it might be my ‘Card A’, as it was the same card that the problem occurred on before.
I turned the EX3 on yesterday with the two cards in it, and I got another error message: “Unknown Media A1 Please change”. This is very strange. According to the manual, that means that I’m not using a compatible card. The EX3 firmware is currently 1.10 which is fine for the cards I’m using. I’ve used the cards on various shoots without any problems whatsoever, or any error messages.
Today I dropped the card into the place that sold it to me, and they are sending it back to Sony.
I am pretty sure the problem is with the card.
Does anyone have any idea, or have you experienced the same or similar problems?
I usually transport my EX3 in a hard case, with the cards in the camera. As far as I’m aware the camera hasn’t experienced any hard knocks, which might damage the cards in the camera. I can’t think of anything else. Do you guys recommend transporting the camera with the cards in it?
Another worry is that by removing and inserting the cards into the camera, I might have damaged one of the “connections” (or whatever you call it) on one of the cards. I’m very careful with cards. They’re either in their box or in the camera. And I insert and remove very carefully, straight in or straight out. Any thoughts on this?
Also I want to ask about the ‘Shutter On/Off’ button under the lens. I shoot at 1/50 as I’m shooting 25p. When I flick the shutter switch to off, I get a much nicer and brighter image than when it’s on, which is great for indoor shooting. However, I’m told to keep it on. It doesn’t seem to make much of a difference to anything really when I have the shutter off, except that I’m getting a brighter image, which is better for me. Can anyone tell me what is actually happening when you have the shutter on or off? If I should keep it ‘on’, why?
Thanks for any help or advice in advance.
