Activity Forums Sony Cameras warming up PMW EX1 image
  • warming up PMW EX1 image
    Posted by Kevin Kerwin on February 5, 2008 at 3:32 pm
    I know that Sony is known for the blue cast color palette and Panny is known for a warmer palette, are there any opinions on warming up the Sony image? In-camera or via Color? Filter and in-camera? Just filter? I have an upcoming shoot in a hospital and have concerns over an overly cold look.
    Thank you!
    Kevin Kerwin replied 18 years, 7 months ago 4 Members · 4 Replies
  • Don Greening
    February 5, 2008 at 7:06 pm
    If it was me I’d probably shoot clean (no filters) and do the color grading in post. Sure, you can warm up the look with in-camera tweaking and/or filters in front of the lens but you need to be using a broadcast monitor during your setup to make absolutely sure the changes are actually going to get you the look you’re after. Normally the only hard filters I ever use are grad NDs or polarizers (for rejecting reflections in glass or water).
    Interestingly enough, I find the unaltered EX picture to be quite neutral rather than being too bluish or reddish. For me that’s a good thing because it takes a lot less work in post to achieve what your final look will be.
    My .02
    – Don
  • Bill Ravens
    February 5, 2008 at 9:46 pm
    Try this…
    Matrix———————on
    Select———————hisat
    Level………………………….0
    Phase…………………………+6
    R-G…………………………..+75
    R-B…………………………..0
    G-R…………………………..-18
    G-B…………………………..-23
    B-R…………………………..-33
    B-G…………………………..+11
  • Steve Wargo
    February 6, 2008 at 3:08 am
    [Bill Ravens] “Try this…”
    Awesome answer
    Steve Wargo
    Tempe, Arizona
    It’s a dry heat!
    Sony HDCAM F-900 & HDW-2000/1 deck
    5 Final Cut (not quite PRO) systems
    Sony HVR-M25 HDV deck
    2-Sony EX-1.
  • Kevin Kerwin
    February 7, 2008 at 5:22 pm
    Thank you for the input guys.
